tractor pulls
Discussion in 'The Garage' started by tecton, Feb 14, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    how do they make multiple engines work on one of those things
    i see them mounted in all sorts of different positions
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    One way: take a divorced 205 and input an engine into the original input as well as the front output. That would get you one engine higher in the frame than the other.
    Another way: Put a heavy series chain sprocket on the crank flange of one engine and the crank snout of another. Butt them together and wrap short a double row chain around both sprockets. That would get you 2 (or more) engines in the frame at the same height. I know this is how the "Odd Couple" Dragster (SBC in front of a 392 Hemi) was done & I belive it is how the "Freight Train" Dragster (pair of SBC's) is done.
    Couple those two ideas together and......
    The 90* ones are a mystery, but I'm guessing some sort of industrial gearbox is used.
  3. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
  4. tecton
    Dec 1, 2002
    1,553
    WV
    thats really interesting
  5. owen
    owen 1/2 ton status
    Nov 21, 2003
    151
    Brewton AL
    I was 'thanking' the other day while I cut grass... My Cub Cadet has 3 blades running off of a single belt- could I run 3 engines in my K5 and just hook 'em together with a belt? Ill keep you guys posted- Im headed out to the garage! "your ass is the grass, and my Blazer is the mower..."
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    hope you can transfer big horsepower and torque through A belt.
