Trade stock sb350 for tune-port setup?
Discussion in 'The Garage' started by roostr3269, Sep 23, 2002.
  1. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    I just had a friend stop by and asked if i would trade my 350 for a tune-port setup from a 86? camaro (305-will it fit a 350?). The motor is the stock one that came out of the Jimmy when i bought it. It ran good when i pulled it, and he said the TP setup comes with everything, Whaddya guys think? Thanx in advance.
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    if it is a spare motor i would say sure.
    you will need a new chip to deal with the added fuel needs of a 350 (i assume u put one back in after the one trading to your buddy was pulled)
    If it is '86 u might have to redrill some of the intake holes. just "hone" them out a bit. nothing major if you can swap a TPI on...
  3. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    If it is an 86 then it uses the MAF sensor which is not really a good idea off road. You will want to convert it to MAP and change the CPU to a '7730. Not a small task but there are lots of people who have done it. Another benefit of of the 7730 is you can run the code and memcal for the 91 trans-am 350 gta which is considered the best for high performance engines and remove the cold start injector which is a PITA for some.
    http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
    http://www.f-body.org/oldfaq/html/faq/ch5.html#ch5-2
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The 305 TPI came with 19 lb/hour injectors. The 350 TPI came with 22 lb/hour injectors. If you're planning to run a bigger cam and/or spend much time in the upper RPM band, you'll need to upgrade the injectors. Other than that, they're the same setup. Since it's a MAF system, be SURE to get the MAF sensor to go with the setup. That little sucker costs around $400! /forums/images/icons/shocked.gif
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    sounds cheaper to get the ford MAF sensor and adapter
    ford ones dont die as often
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Never heard of that trick! Do you have a link to more info on that mod?
