Trail pressure for Irok's ????
Discussion in 'The Garage' started by Supreme70, Apr 3, 2007.
Irok tire pressure for the trail
  1. 30 lbs
    0 vote(s)
    0.0%
  2. 20 lbs
    1 vote(s)
    6.3%
  3. 15 lbs
    3 vote(s)
    18.8%
  4. 10 lbs
    3 vote(s)
    18.8%
  5. 8 lbs
    9 vote(s)
    56.3%
  1. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    Im wondering what tire pressure you guys run your Iroks at on the trails and rocks. Going playing this weekend and would input at what you guys like best, I dont have rock rings on my rims.
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i ran then at 22psi on the street. i never needed to air down on the trails, but in the sand i took them down to 8psi on 15" steel rims w/o any problems
  3. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,006
    839
    Pinckney, MI
    8" 10" or 12" rims
    If you run 8 you can run it a little lower, but trail pressure sould be 10-15 psi depending on rims.
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
  5. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    10 front 8 rear on 8'' wide rims but my sub-buggy only wheigh's 3700lbs. I have had exellent results and only blown 1 bead but I jamed the tire sideways into a huge rut going faster then was reasonable. Irok's conform and flex better than other tires I have ran at similar pressure ranges. J
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    keep in mind hes running 16x10's, not 15's. i stand by my 10psi vote with no beadlocks
  7. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    37's on a 16x10 . I put them at 12 with no problem.:thumb:
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    start at 10-12 & work down if you think you can.
    Harley
  9. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    This applys to just one type of terrain but on slickrock such as Moab, going from 10 to 8 psi was an amazing difference. So like has been said start at 10 and go as low as you dare
  10. goofy1
    goofy1 1/2 ton status
    Feb 13, 2005
    338
    Woodhaven,Mi
    4-5lbs sounds good then you would be able to test the new compressor LOL
  11. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    Im running a 16 x 10 rim But have never had a chance to air down. Thanks for all the info guys, I believe I will go down to 10 and see how it works. Ill let you guys know, thanks
  12. goofy1
    Feb 13, 2005
    338
    Woodhaven,Mi
    What? I don't deserve a response? 4-5 lbs would be entertainment for the rest of us on Sat. and you would get great traction until.....:D Hey what time were you thinking for today? call or something
    -Tim
