trail ready!
Discussion in 'The Garage' started by screamer*145, Oct 11, 2004.
  1. screamer*145
    screamer*145 1/2 ton status
    Oct 23, 2003
    174
    cottage grove, mn
    ok i need some help or ideas on what to do and or check before i take her out for some action just mud and hills no rocks or trees so any ideas are welcome just so i dont for get some thing and this is probly going to be my first real outing so help is thanked!
    so you know what i got - 78 blazer 14ff/d44 th350 np205 and a 400ci have 32" tires with no lift /forums/images/graemlins/thumb.gif
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    check all the /forums/images/graemlins/thumb.gif fluids and make sure all the u-joints are good, ow and grease all the grease fittings. pretty much just look over the whole truck and make sure nothing is worn out or loose.
  3. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    make sure that the ubolts are tight too, it is not uncommon for them to loosen up overtime.
  4. screamer*145
    Oct 23, 2003
    174
    cottage grove, mn
    i have found that the top of one of the rear shocks is loose and rusted my ? is that can i /forums/images/graemlins/grind.gif it off and just put a bolt throuh it and nut it and what kind of gabrial schock would i need for the front with no lift and ferd towers and which ones for out back! /forums/images/graemlins/waytogo.gif
  5. screamer*145
    Oct 23, 2003
    174
    cottage grove, mn
  6. camok10
    camok10 1/2 ton status
    May 1, 2004
    288
    Tucson, AZ.
    Punctuation would be useful for keeping people un-confused.
  7. screamer*145
    Oct 23, 2003
    174
    cottage grove, mn
    i have found that the top of one of the rear shocks is loose and rusted in. Can i just cut mounting hardware off and just put a bolt throuh it instead, also what kind of gabrial schock would i need for the front with no lift and ferd towers and which ones for out back.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/ears.gif
