Trailer axles
Discussion in 'Tow & Trailer' started by CrewCab59, Nov 27, 2005.
  1. CrewCab59
    CrewCab59 1/2 ton status
    Aug 13, 2005
    483
    Knoxville ,TN
    Can anyone tell me if older construction trailers used mobile home axle?This trailer has bud 14.5 tires ,the brakes are adjustable like norm.
    Trailer spec.. 1990 18ft with dove 8'' wide frame ,16,000lb triaxle.
    New wood deck,jack,pintle eye,tires brakes,lights,and would though in the receiver and hook. $1000.00
    what do you guy's think.Any help would be great...
  2. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    The 14.5" rims make me think they are deffinately mobile home axles, I've never heard of other rims that size. The easiest way to tell is to look at the middle of the wheel. The mobile home axles have no center, just the outter rim.
  3. CrewCab59
    Aug 13, 2005
    483
    Knoxville ,TN
    Yes, wheels have no centers.The axle tag 5500lb ,I thought mobile home never listed a lb or any tag?I now this trailer is very well built, is't painted construction yellow even the under side, wires for the lights in steel tube like from the factory..
    anybody else have info??
  4. cok5
    cok5 Registered Member
    Apr 27, 2004
    89
    IIRC heavy duty trailers had a wheel/axle combo that were the same "style" of mobile home axles but were definetely not mobile home. 5500 lb rating is dang high! Sounds like a good deal. You can swap regular "outers" onto mobile home axles, I just can't remember the home brew recipe!
  5. afroman006
    Aug 21, 2002
    2,876
    They will work fine, but the 14.5" tires are a bitch to find.
  6. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    They are actually cheap and easy to find out here anyway. Last set I bought were $50 each at commercial tire in Central Oregon for 8-14.5. Got them to move a house a couple years ago, now I use them as spares for my car trailer since it came with MH axles. Best part about them is they are basically a low tire with a good load capacity so the fender or deck doesn't stand too tall.
