Trailer, Blazer & Camper all on the Gooseneck W/ Tow Rig *PICS*
Discussion in 'The Garage' started by therobzilla, May 23, 2004.
  1. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    OK,
    Here it is not totally done yet, but almost. Got the "Taco" wagon aka camper mounted on the gooseneck, and loaded the blazer on the trailer to check out the clearances and take it for a test drive.
    Still have to have the side boxes finished at work, door fronts hopefully will be diamond plate, and have to have the D Rings mounted in the right spots. and make the hold downs for the ramps, and adjust the trailer/gooseneck height. Then it's off to the mountains this weekend for some wheeling/camping/fishing.
    I't totally digging this setup.
    Enjoy.
    Here are the pics:
    Thanks,
    Rob
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Wow thats quite the set-up! You said you took it for a test drive? How did it pull everything? How do you have the camper mounted on there? Very nice /forums/images/graemlins/peace.gif
  3. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    I hope that cummins isnt bone stock...... that looks heavy.
    Beautiful setup man.
  4. therobzilla
    May 15, 2001
    1,307
    Gilbert, AZ
    Tows like a dream, 70/75 like it's not even back there. No sway, no bumping, no issues what so ever, take a bit of time to get up to speed, but other than that, it track like an arrow.
    I mounted the camper thru the deck and into the actual cross members of the trailer and bolted it down, then I built little knee walls on each side of the over hang and then am going to have the knee walls covered to look like utility boxes.
  5. therobzilla
    May 15, 2001
    1,307
    Gilbert, AZ
    Brad,
    Not totally bone stock. It's got an edge ez and some other goodies on it. Tows no problem., with the setup as it is. Got the Scotty II breather, Edge EZ, and some others...
    Got to do some other things like a aftermarket clutch, etc....
    Rob
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Thats pretty damn awesome Rob. Looks really cool and should work very well for you. I am totally jealous. /forums/images/graemlins/thumb.gif
    Harley
  7. white-rhyno
    Jan 27, 2002
    942
    Rob, about what elevation are you running at?? I took my moms 2000 cummins to montana and it ran like dog poo. But here at 1500 ft it dynos at 280hp and 680ftlbs. Thats rearwheel power and it only has a five level chip (110 hp)and striaght pipe. Also what are you average egts?? I dont like her chip cause it gets hot.
  8. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    AWESOME setup /forums/images/graemlins/thumb.gif /forums/images/graemlins/peace.gif
    And thanks for the variety of pictures. /forums/images/graemlins/histerical.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/waytogo.gif
  9. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    Nice set up!! You're totally self contained, ready for anything. /forums/images/graemlins/waytogo.gif
    BTW/ How much is your next door neighbor asking for his house? /forums/images/graemlins/whistling.gif
  10. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Rob is so !
  11. therobzilla
    May 15, 2001
    1,307
    Gilbert, AZ
    House next door sold in 5 days, and went for $325,000.00 /forums/images/graemlins/eek.gif.
    As far as elevation is concerned it about 1200ft and it has a 4" exhuast, and running a Scotty II intake. The edge ez puts 65 HP to the rear axles, and it's plenty for towing, without replacing the stock clutch. The EPROM was flashed at the dealer for the high preformance setup back in 99, and had bigger injectors added.
    I have heard of some guys having towing problems right off the lot. I bought mine used with 126K miles on it. Steady as the day I got it. It's not going to run 85+ mph up the grades, but it will pull 65/70 in the grades no problem. I don't need to break a need speed record towing, just need to get there safely and in comfort.
    Once I dump the utility box for a regular dually bed, it will be much better, will drop about 1K to 2K in additional weight. The Utility body is kinda heavy.
    Can't complain.
    Rob
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I love it, and I would love to do something similar if I can figure out where to store it... /forums/images/graemlins/frown.gif
    So, when you run across the inevitable "better deal" right after you buy something, let me know... /forums/images/graemlins/laugh.gif
  13. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    Now thats the set up!!!!! /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
