Trailer Brake away kit??
Discussion in 'The Garage' started by 90blzr, Sep 15, 2003.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Anyone have one or ever had the need for one? I've heard a few people that have gotten them, but never used them.
    I've also heard that they can do more harm than good /forums/images/graemlins/confused.gif
    Anyone have any experience with the brake away kits versus the regular saftey chains?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Every trailer require by law to have brakes must have both brakeaway and safety chains. One is not a substitute for another.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Who's your source? I've been using breakaway gear for over 15 years both personally and at work and I've never once had an issue with it causing "harm".
    Breakaway switches are a cinch to use: hook it up and go. Once you're done, unhook it.
    And like Tim said, if DOT catches you towing a trailer that's not equipped with a breakaway switch AND safety chains, I would imagine you'd be in a little bit of trouble.
  4. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    yep yep gotta have the breakaway switch if your trailer has brakes. Campers with breaks require them too. The only downside I had was the time my pop in law hooked up the camper and got the breakaway line tangled in the chains. I pulled out and went around the first turn and the wire pulled out of the switch locking the brakes and giving me a heart attack until I figured out what it was /forums/images/graemlins/rolleyes.gif
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Although this is not true for every state, but should be considered /forums/images/graemlins/thumb.gif
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Required by law in MOST states.
    Its barely noticable. Doesnt interfere with anything.
    Chains are your first line of defense against a run away trailer. If your hitch ball comes undone/snaps/ or the lock brakes free, , the trailer chains will catch it.
    trailer brakes on the other hand, is the second line of defense, should your trailer break totally free from your truck.
    You should mount it to part of your frame, something that is seperate from the hitch, just in case your whole hitch breaks away.
    P.S: if you happen to have a SURGE brake however, I do not believe break away kits apply.
