Trailer brake controller
Discussion in 'Tow & Trailer' started by gmcjimmy4x4, Apr 20, 2007.
  1. gmcjimmy4x4
    gmcjimmy4x4 1/2 ton status
    May 6, 2005
    132
    Sacramento, CA
    Never had a trtailer big enough to need braks before. Not sure what to buy and is it easy to install? Dont use it often, so i dont need anything to fancy. But it does need something. Any suggestions?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    They are so easy to install . Red to the cold side of the brake switch , black to positve battery terminal ( weird they use black ) , white to ground of battery , and the blue runs back to the trailer connector .
    Look on towrig.com for input as to what brand .
    I run an Activator on my pickup since it came with the purchase of my camper . And on my Blazer , I bought a Hoppy from Autozone with a digital readout . Both actually work fine for my 3000 pound trailer .
    The more expensive ones have better control from what I read though .
  3. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I have the draw-tite Intella-Stop UltraTM , it is the same thing as the Tekonsha prodigy. Same company, different name. This is by far the best brake controller I have ever used. You do not have to level it and set anything. It automatically senses the angle you mount it at and the more your vehicle nose dives (when you hit the brakes harder) the more it applies the trailer brakes. It also has a booster button on it that comes in real handy. For instance when I am in town I turn the boost off because I don't need that much assist from the trailer. However when I am on the interstate I bump the boost on so the the trailer brakes will engage a little sooner and harder when you have to stop. Shop around and you can find them at pretty good prices. I paid 84.00 to my door.
  4. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    I just ordered a Tekonsha Prodigy from RVwholesalers.com for the Hubbies Duramax, but haven't towed with it yet. Look like there is a new Prodigy, too, called the P3. Must be really new as it wasn't offered a couple weeks ago when I bought ours. I did some research before I bought it, mostly at towrig.com. It seemed the consensus was for the Prodigy. Some guys swore by Brakesmart, but it seemed harder to install. Good luck.
  5. blowedupmotor87
    blowedupmotor87 1/2 ton status Premium Member
    Mar 14, 2007
    2,489
    16
    Charlotte, NC
    I bought a Tekonsha Prodigy and the only install problem I am having is figuring out where the heck to mount it! :confused: I am thinking somewhere in the realm of above and to to the right of the gas pedal on the angled part of the dash (less than 70 degrees of course). I don't know when I am going to use it though, I bought it 'cause my buddy thought I'd need it to tow a trailer for him but, ended up it had surge brakes and, he got a different truck to tow it. Oh well. :D
  6. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    I am buying a truck in bragg, You could always pick it up and bring it to Tn for me:wink1: Would be a good test, I could even through in a case of beer:D
  7. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    just got a new travel trailer.. so of course a new controller was in order. snagged a Tekonsha Prodigy and put it in after i brought the trailer home. Took it out last weekend and WOW,what a difference! Wish i woulda done it years ago. TT weight (on the scale) was just over 7000...
  8. gmcjimmy4x4
    May 6, 2005
    132
    Sacramento, CA
    hey woody, What are you towing it with?
