trailer brake controller
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by steve_97, Mar 20, 2002.
  1. steve_97
    steve_97 Registered Member
    Feb 27, 2002
    25
    Boise, Idaho
    Any one know of a good trailer brake controller to use? I need to be able to stop with my 6000 lb blazer on a trailer.
    thanx for the input.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    The best contrroller on the market is the made by Tekonsha. The Voyager is really simple to setup and works like a charm.....
  3. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I use the Reese Brake controller from Kragen. It does me just fine. It cost about $50. I usually end up towing everyone else's K5's around with my Suburban. It's not the most fancy but it's simple to use and hook up.
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    I got the 'Voyager' as well. It works great and the install was straight forward. I tow a 5000 lb trailer with my Jimmy.
    Rene
  5. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Go with the Voyager. I tow a 7000 lb travel trailer with my short box 1/2 ton. Works great. Stay away from the brakeman style controller junk. The coolest controller i saw used input from the brake peddle. It had a cable that went from the peddle to the controller. I found it on the internet cannot rember who makes them but the idea is good. No level or gain to set.
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Another vote for the Tekonsha. The one in my K5 has been trouble free for many many years.
  7. punchdrunk
    punchdrunk Registered Member
    Jul 7, 2001
    33
    santa cruz, ca
    I use a DrawTite activator II,it's solid state, small,simple to use and is good for up to 3 braking axles,The Reese Model is the same product under the reese name.I think it was about $100
  8. TULSAK5
    TULSAK5 Registered Member
    Feb 20, 2002
    93
    Broken Arrow, Oklahoma
    Richard, I seem to recall a certain K5 that has pulled you more than once.
  9. TULSAK5
    Feb 20, 2002
    93
    Richard, I seen to recall a certain K5 that has pulled you more than once.
