trailer deck question
Discussion in 'Tow & Trailer' started by big83chevy4x4, May 4, 2006.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the main question is wood or steel?
    im thinking about building my own trailer, but im torn weather or not to use a wood deck or steel diamond plate deck. im sure the supports would have to be different for each, also trying to price it out. im also conserned about weight.
    is 1/8" diamond plate enough with supports every 2 foot?
    id use 2x6 treated if i use wood, but what would be a good spacing for the supports, 16"? id probably use 4" c channel for the deck frame, its going on top of another frame otherwords i would use 5" or 6"
    what i have planned is 18' 8' wide, the heaviest thing it will carry is my truck.
  2. ivie29
    ivie29 1/2 ton status
    Apr 26, 2006
    212
    gypsum, colorado
    I have a bumper pull trailer with an 18 foot deck and it has 2x12s on it. The support spacing is 18 inches and this seems to bo ok. The problem is that the pressure treated wood doesnt last very long. The next time that I need to redeck I think that I'm going to use expanded metal. This shouldnt be much heavier than wood and will last a lot longer, also mud will fall right through.
  3. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    294
    Truckee, CA
    From someone that doesn't have a trailer, i say wood. Its cheap, easy to repair, lasts fairly long, you can screw random things to it you don't feel like strapping down, good traction, lighter, easily replaceable down the road, etc.
  4. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    I keep having problems with my wood deck.The wood keeps warping. I am at work and can't tell you how far apart my supports are until Monday. I am thinking about going to metal myself.
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the more i think about it im thinking steel over wood. there is alot of cost in the steel, but never replaceing would be nice. i got a rough estimate (no weight for c channel) in the weight and it looks about 1000 lbs total, isn't as much as i though it would be. the wood would be about 600 lbs im thinking.
  6. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    If you are going to use 1/8 I would double it for the wheel treads, that is awfully thing metal.
  7. Orange Crush
    Orange Crush 1/2 ton status Premium Member
    Mar 6, 2003
    440
    St.Stephen S.C. 29479
    Keep in mind steel will be slick. Especially if you get any oil or what not on it. I have had my trailer for 7 years with a treated 2x10 deck and it shows no signs of rotting and it is stored outside.--Eric
  8. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    I went with untreated 2x12's and just put Thompson's on it every year. Doing OK so far after 5 years. It cost $300 to deck it, so I sure don't want to do it again until I have to. I know a guy who bought rough-sawn planks from a saw mill and treated them with used oil once in a while. Seemed to work OK for him, but I can't tell you how long it lasted. He sold it.
  9. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Mine is made of 3/16 tread plate steel (diamond plate)
  10. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    Keep in mind that steel will also add strength to the trailer where wood won't.
  11. 73k10sub
    73k10sub 1/2 ton status
    Jul 23, 2001
    223
    Tulsa, OK
    Aluminum
    I recently saw an interesting deck on a home made single axle utility trailer. The guy had used aluminum salvaged from bleachers at some athletic facility. I believe his runners were on 16" centers. I have no idea about the strength of this with regards to using it to re-deck a car hauler. It looks like a good way to save some weight. You would probably have to know somebody to get your hand on this kind of material what with scrap prices being what they are. Good luck!
  12. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    Keep this in mind, once the deck get's wet, if it diamond plate, it's slicker than greezed owl $hit. It's hard as hell to not slip around on. Including your rig or yourself.
    I used wood on my deck on the gooseneck. I used the speciality Auto Trailer Deck screws and it worked great. Easy to upkeep and cheat if I have to replace.
    Just my opinion.
    Rob
  13. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    steel gets hot as hell in the sun... is loud as hell if you drop something metal on it (2am at the camp site... you'll make enemies) and it can be spendy too.
    I'm going with wood, though I may use the steel mesh stuff in the middle (the whole length, between the tires). Not 100% sure yet.
    j
  14. k5onswampers
    k5onswampers Registered Member
    Mar 9, 2005
    90
    Port Saint Lucie, Florida
    the deck plate(steel diamond plate) is Awsome but pricey. Wood is exellent for cost and it lasts along time mine is 5 years old and wood is in great condition. And you have to watch out with the expanded metal it doesn't support the weight good it will break near the welds if there is alot of pressure.
