Trailer harness wiring help please
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kmbonomo, Nov 9, 2001.
  1. kmbonomo
    kmbonomo 1/2 ton status
    Jun 12, 2000
    115
    Traverse City Michigan
    Im putting a 4-flat wiring harness coupling on my vehicle and dont have a trailer to test, the 4-flat has a white, brown, green and yellow wires.. what do they go to, i assume white is ground... HELP Im leaving to pick up a boat in the morning.. thanks... which color is left / right turn, brake ,running lights
    Go Topless or don't go at all !!!
    <font color=red>83 K5 Full Convertible Conversion</font color=red>
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Green - Right
    Yellow - Left
    Brown - Tail
    White - Ground
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
  3. dyeager535
    26,979
    Go buy one of the adapter plugs from the local auto store. $15, and you will save yourself and any PO wiring headaches, and time. It's foolproof, and besides soldering and sealing wire splices if you went that route, the right way to do it. It just plugs right into your tail light wiring harness. I'm pretty sure '83 was using weatherpack connectors at that time, as I think thats all the adapter "t's" fit.
    Dorian
    My tech/links page: &lt;a target="_blank" href=http://www.dorianyeager.com/index2.html&gt;www.dorianyeager.com/index2.html&lt;/a&gt;
    Why insist on counting when the ring gear has the tooth counts stamped in?
  4. kmbonomo
    Jun 12, 2000
    115
  5. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Keith, Michael's right. Those are on the wiring diagram (which I happen to be studying, in my own wiring hell...) [​IMG]
  6. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Unless you drive a dodge, in which case, God help you on the colors.
    Sherman, Tx
    <font color=red>The blazer's almost on the road....anyone got tree fiddy?</font color=red>
