Trailer question
Discussion in 'Tow & Trailer' started by 84gmcjimmy, Jun 17, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Don't worry, I am not getting a trailer.
    I have a question though.
    Whats the difference between a trailer with a hitch to your bumper/hitch mount, or using an in bed dove tail structure? Dis/advantages? Thanks /forums/images/graemlins/waytogo.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Difference is where they hook up (duh)
    Bumper pull:
    advantages:
    cheaper to buy
    cheaper for hitch equipment
    can still use the bed
    lighter weight
    flexability of tow vehicle
    disadvantages:
    sway is a possibility
    gooseneck/5er
    advantages:
    feels much more stable when towing
    doesn't sway at all
    tighter turning radius
    disadvantages:
    must tow with a pickup
    usually must have a h/d pickup because of heavy pin weight
    trailer itself is heavier
    more expensive hitching equipment
    I'm sure some others will chime in and give you more info.
    Check out my webshots, my tow rig is set up for both bumper pull and 5th wheel. /forums/images/graemlins/thumb.gif
  3. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Goosenecks are usually rated to haul more weight than bumper mounts.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yep.
    Gooseneck rating = 25,000 lbs, 4,000 lb pin weight
    5th wheel 15-30,000 lbs, 4,000 lb pin weight
    Ball hitch with weight distributing setup, 10,000-12,000 max
    Pintle hooks 15k is common, but they come heavier (although no hitch is rated for that kind of weight nor is any pickup so I guess it doesn't matter).
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    /forums/images/graemlins/histerical.gif That just cracked me up for some reason /forums/images/graemlins/histerical.gif
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay thanks I understand now.
    /forums/images/graemlins/woot.gif
