trailer springs question.
Discussion in 'Tow & Trailer' started by blazindorito, Oct 10, 2006.
  1. blazindorito
    blazindorito 1/2 ton status
    Nov 25, 2003
    2,047
    Southern California
    I bought a trailer to haul 2 quads. The question is can I do the same with the springs as some trucks do the springs over axle. I want to get a much higher stance. It already has 15" tires or what can I do if I can to make it get higher? Thanks. It's a single axle.
  2. sweetk30
    Nov 1, 2004
    25,536
    532
    horseheads , ny 14845
    most you will need is new ubolts and new center pins. but yes flip it is possible. done lots of times. the new center pin is for the nut and head on wrong sides of the spring pack.
  3. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    If it has a cambered axle you will need to weld new spring perches on the top of the axle. if you just flip the axle over the camber will be out of whack and you will get some pretty bad handling and tire wear.
