Trailer Wiring
Discussion in 'The Garage' started by ProJunkRacing, May 27, 2006.
  1. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    Hey I am wiring my trailer and I got a wiring kit . It came with lights all the stuff for the 4 flat wire connection. well I bought the connector for my Gmc the 7 way plug since it has electric brakes . but it seems the kit wiring differs from the cover on my truck that says what wire is what , well the plug seems to have all the connections but yellow? wtf i hav aux left, blue ,red,and black i need help anyone got a link to a good tech writeup on wiring trailers. also i hear that the ball serves as a groun and trailer must be connected is this true? also help wite elec brake wiring please thanks
  2. 73k10sub
    73k10sub 1/2 ton status
    Jul 23, 2001
    223
    Tulsa, OK
    Ground
    I can't help with the 7 plug stuff since I only have six. You should be able to buy a 7 to 4 adapter plug at WallyWorld or a trailer place.
    NOTE: Do not rely on the trailer hitch being on the ball for a reliable ground - it won't! Ground both the tow vehicle and the trailer for reliability.
  3. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    Here is a pretty good writeup on trailer wiring:
    http://www.marksrv.com/wiring.htm
    I agree with 73K10sub. Don't use the ball for a ground. Sometimes it works, but it is a bad idea.
  4. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    well that is pretty good that helps alot
  5. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    ok another question one wire is for battery well my trailer has no battery , it has breakaway switch but no battery ,any one know of place to find good diagram for the brakes end of it i am completely rewiring it
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    A lot of times, if you go up to your local U-haul and talk to the hitch install department, you can get a wiring diagram that fits your needs.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Walmart sells a trick trailer socket for mounting on the tow rig. It has a 7 prong outlet AND a 4 prong outlet built into the same connector. Very slick setup. With it you don't have to worry about losing the 7-to-4 pin adapter that you otherwise need for towing smaller trailers. :cool1:
  8. 73k10sub
    Jul 23, 2001
    223
    Tulsa, OK
  9. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    dude that is trick thanks so much
