trailer ?
Discussion in 'Tow & Trailer' started by hd-10, Mar 23, 2005.
  1. hd-10
    hd-10 1/2 ton status
    Jan 31, 2004
    188
    lemoore, ca
    how can you tell the weight cap. of the axles on a trailer?
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    294
    Truckee, CA
    If its a professionally made trailer, there should be a capacity sticker on it somwhere.
    Besides that, only way i would be able to give a rough estimate is by lug pattern........
    I would just assume 8 lug trailer axles would be pretty high capacity (5000lb each?)
    But thats just my 0.02, hope someone else has a better answer for you!
  3. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    If they were 8 lug I would assume AT LEAST 5k, more likely 7k though. The 5200 pounders on my trailer are 6 lug. I thought they were going to be 8 lug (so I wouldnt need a spare) but oh well.
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    and my 5 lug axles are 3500 lbs
  5. dhcomp
    Mar 17, 2001
    9,862
    294
    Truckee, CA
    The size of the 5 lug pattern may be an indicator too.
  6. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    i have a 10k trailer and its 6 lug with torsion axles. go figure.
  7. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I have a 7K trailer with 6 lugs. Its hard to tell by just looking. A trailer shop might be able to tell by looking at the hub.
  8. hd-10
    Jan 31, 2004
    188
    lemoore, ca
    all right found a trailer it is a deck over trailer 20,000 gvw has anyone ever towed with a deck over and or what is the ups and downs of having one over a regular trailer?
  9. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Do you have your Class A licence? If not don't buy a trailer over 10K GVWR to use in California.
  10. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    what info do you have to back this? i towed a 32 foot Goose deck over from oregon to yume going down I-5 to I-8 and passed a TON of cops never had a problem. i was doing 5 to 8 MPH over the entire time. i was OVER CGVWR of my dodge as well and nobody said anything. you only need a class A if you are over the weigt limit. then there is much more to it than having just a class A. you will need a trip ticket as well.
    Grant
  11. hd-10
    Jan 31, 2004
    188
    lemoore, ca
    the trailer will be regestered in oregon i will look up the gvw limits thanks.
