Trailmaster 4 way shocks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KapeKodK5, Jan 19, 2001.
  1. KapeKodK5
    KapeKodK5 Registered Member
    Mar 3, 2000
    I was wondering if ayone knows anything about these shocks.. they would look sweet on my blazer.. They are a shock with a yellow coil spring over the body. But if they are not are good then I stick with the 9012's
  2. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    Spring Valley Lake Ca.
    they are designed for hauling loads and trailers they are called load levlers or used to be most blazers ride stiff enough ive seen guys remove leafs then run those.also think about replacing your shock mounts youll have to soon after you install those.
    88k5 silverado w4"lift soon to have <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
