Tralier Brakes
Discussion in 'The Garage' started by 1979jimmy350, Jul 13, 2005.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    How are trailer brakes normaly wire to a truck. I belive that my truck already has the wire for them on it. I have two good size wires running the length of my frame that are taped off near my hitch. At the other end one runs to the junction box where the trailer harness hooks in to and the other looks like it is a ground that was cut because it is just laying there.
    With this system do i need a brake controler in the cab?
    How would i wire into the trailer it has four brakes on it?
  2. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    As far as I know, ALL electrical trailer brake sys. need an "in cab" controller.
    The way that moste of them are wired is:
    1) wire from brake light switch to controller
    2) wire from batt.+ (with 30A fuse) to controller
    3) wire from ground to controller
    4) wire from controller to trailer plug
    Hope that helps, if I missed any thing I'm sure some one else will spot it ;)
  3. Boondocks
    Boondocks 1/2 ton status
    May 10, 2005
    129
    Massachusetts
    Also the heavy ground to the trailer plug.
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    So what exactly does the controler do? i have never messed with trailer brakes before so i am trying to learn
  5. Geargrinder
    Jan 21, 2005
    258
    Medford Oregon
    There are 3 types:
    1) the old style that taped into the hydralic brake sys. so the trailer brakes worked in unison with the truck
    2) "time delayed" they start with a low signal when U 1st put your'e foot on the brake, then they gradualy increase the signal strength till it hit the max voltage (U set the max signal with a dile)
    3) "pendulum style" they have a little gizmo in 'em that has to be leveld and set just right so it will work all most as good as the old style.
    I use the "time delay" style my self, it simple and eazy to set, and it works great for me.
