tranfer case question?
Discussion in 'The Garage' started by lunchbox, Oct 24, 2006.
  1. lunchbox
    lunchbox 1/2 ton status
    Jan 22, 2006
    309
    novato,california
    first the rear end now a blown up transfer case, ive had a bad month. i just blew up my transfer case and im gonna go to the pick and pull tommorow, what should i be looking for? one out of a suburban? or another blazer?
  2. dyeager535
    26,979
    Need the year of your rig! :)
    (fill out your profile, some us actually check that if it's not in the post hint, hint) A signature line also works.
  3. lunchbox
    Jan 22, 2006
    309
    novato,california
    soory about that. Its an 87 gmc jimmy with a 305 and a 700r4.
  4. dyeager535
    26,979
    I believe any GM 1/2 or 3/4 ton from 1989 down to 1981 will have a case you can use. Someone will correct me if that's wrong.
    You should have an NP208 case in there now, I believe the mechanical speedometer NP241's will bolt straight in as well. (again IIRC, 1988-89) They are more desirable than the 208, but if you can't find an NP241, I wouldn't cry. :)
    You COULD use one from a 1990 or 1991 truck of the same body style you have (not the '88+ bodied trucks) but that will have the electronic speedometer, making you change a few things around.
  5. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Should then have an NP208. Any 4WD Chebby from that year would work -- Burb, Blazer, pickup, all use the same t-case ... as to which other years, someone else will pipe up.
    I know that by '90 the NP241 was in use, with the digital speedometer (VSS, DRAC) stuff, so you'll want to avoid that to keep your swap plug-n-play.
    -- A
  6. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    My theory..
    I try to get tranny and transfer cases from 1/2 tons,figuring they would be less likely to have been hauling lots of weight or abused...see if the donor truck had a class 3 trailer hitch,that means it was hauling a camper,or other heavy loads,and the drivetrain might be beat!...the worst trucks to use parts from are ones owned by contractors,1 tons especially..they get beaten by employees,and are often overloaded and neglected..but we need 1 ton parts,and sadly,there just isn't many to choose from here...:crazy:
  7. lunchbox
    Jan 22, 2006
    309
    novato,california
    that makes sense, so the transfer cases were the same in 1 tons and 1/2 tons?
  8. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yep, 81-89, 90-91 have electric speedo. the 700r4 and th350 versions have a 27 spline input. the sm465 and th400 versions have a 32 spline input. i have seen a few 4 speed overdrive manual trannys, these have a 27 spline also.
  9. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the 1 tons have a np205, they won't bolt into your truck. the 1/2 ton and 3/4 ton are the same though.
  10. lunchbox
    Jan 22, 2006
    309
    novato,california
    so i could find one in a suburban?
  11. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yep
  12. lunchbox
    Jan 22, 2006
    309
    novato,california
    how hard of a project is replacing the t-case, any tips?
  13. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    its not that bad with the newer cases they are no where near as heavy, you have to remove the shifter, drive shafts and then unbolt the transfer case from the adapeter, its not to bad at all
  14. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,614
    71
    Living in a dump, VA
    better know your transimittions though...mine might be a rarety but i got an 87 burb with a f/i 350 but it has a turbo 400/208....is this a rarety to find?
  15. dremu
    Feb 27, 2000
    15,958
    452
    Nah, the 3/4 Burbs have the TH400, and through '87 would have the 208.
    My '90 Burb had a TH400 and a '241.
    -- A
  16. lunchbox
    Jan 22, 2006
    309
    novato,california
    so my dad and i went back to where i broke down and we tried to pullit home with his truck, the thing wouldnt budge, it was dragging the front tires . we had put the tranny and t-case in nuetral and the thing wouldnt move, and when i called the tow company they said they couldnt help. what does this sound like and how the heck am i gonna move this?
  17. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    if the transfer case is locked up pull the drive shafts, just remember though that you will not have park so use the parkign brake so it does not roll away
  18. goldwing2000
    goldwing2000 Guest
    Yeah, sounds like you grenaded enough parts inside the t-case to lock everything up. Good job! :waytogo:
    Just disconnect the driveshafts from the axles and tie them up to the bottom of the truck. If you pull the rear shaft completely out, you're going to be dribbling fluid all the way home.
    And don't lose the hardware. :D
    Leave the tranny in park and the t-case in neutral, so you can start the engine and have brakes.
  19. lunchbox
    Jan 22, 2006
    309
    novato,california
    so it doesnt sound like any of this hurt my tranny did it?, its just the t-case?
  20. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    From what it sounds like the planetiary in the transfer case exploded I have seen this several times with rigs that were wheeled hard or run out of oil. pull all the drive shafts and put them in the truck.
    bigred81
