tranfer case questions
Discussion in 'The Garage' started by eldickey1, Feb 25, 2006.
  1. eldickey1
    eldickey1 Newbie
    Feb 25, 2006
    OLYMPIA, WA
    Hello everyone, Please educate me.
    I have an 82 3/4 ton 4 speed. I recently blew a chunck out of the rear right side of the transfer case. I believe it was the chain which would make it a NP203. Am I correct?
    I don't have any experience with transfer cases, so can someone tell me the difference between the 203 and 205 and if I can use the 205 in my truck.
    I undrstand the 205 is gear driven and that there are a different number of spline involved. please elaborate.
    Thank you,
    Edward Dickey (DickEddie)
    eldickey1@yahoo.com
  2. jaredmajor
    jaredmajor Registered Member
    Mar 2, 2005
    96
    Anchorage, AK
    check out offroaddesign.com, they have it all on there.
  3. eldickey1
    eldickey1 Newbie
    Feb 25, 2006
    OLYMPIA, WA
    thanks Jaredmajor
  4. bigkennye
    bigkennye Registered Member
    Nov 8, 2005
    45
    virginia
    81 chevy blazer
    I have an 81 and from what i have gathered, chevy moved from the np205 (gear drive) to the np208 (chain drive) in 80-81 i think, so that would make yours an np208 if I am correct, I also believe that the np203 is a full time 4wd case, but dont quote me on that, i am sure it was the earlier transfer case used before the np205. and just like you I am curious as to the differences between the 205 an the 208, is the 205 stronger? I would like to know also, after all I am still a beginner an my rig sitting for the last 2 months with the wheels chocked, due to a tranny problem, should be proof enough that i am still a noob, LOL:doah:
  5. jonny reb
    jonny reb Newbie
    Feb 25, 2006
    3
    kentucky
    205 is definitly stronger, it is gear driven and has a cast iron housing. a 208 has an alluminum housing that is not as strong. but the 208 has a better low range and if you still have stock axles the 208 is fine because the axles will break before the t-case
  6. bigkennye
    Nov 8, 2005
    45
    virginia
    options
    Thanks for the info, as with all vehicles different options and everything that are usually available, the 3/4 ton an the 1/2 ton stock axles could be the same, mine are stock 10 bolts with auto locking hubs, except for the engine swap everything on mine is stock, and I drove mine off a 15 foot cliff and it still ran, but shortly thereafter things are breaking left and right, as of now the brakes need to be done as well as the tranny, other things were that i had to reinstall one of the headlights and of course they all need to be readjusted, i did the best job i could, shocks were broken off, so i have replaced those, the drivers side electric window no longer goes up an down. but summer is right around the corner, and i am looking forward many hours under the truck and everywhere else on it also, hell i might become a pretty good fabricator by next winter.:haha: My friend who was in the passenger seat recommended that i get a roll cage and some good seats with 5 point harnesses, I think I may have skeered him a little bit.
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    There are 2 chain driven cases. The 203 which you shouldn't have behind a 4 spd. and the 208 which was behind the 4spd in the 80's. The 208 has an aluminum housing and has a little round plate on the back side that says the lowrange (2.61:1) and the model 208.
    The 208 is usually a pretty good case except in extreme circumstances or with heavy usage and poor maintanence. They are pretty easy to rebuild if you need to and they are pretty cheap to find a replacement tcase in good shape.
    Harley
  8. bigkennye
    Nov 8, 2005
    45
    virginia
    is there any other maintenance than changing the fluid (ATF, correct?), that is necessary? and how often should the fluid be changed?
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i agree, the only down side to a np208 is the aluminum case, it will break if you smack it, i have 1 broken case here from that.
    i change my fluid every spring, unless i think i may have water in it, then i change it. most people use ATF in the np208, but i have found a while back that it was built to run 5w30. ATF works just fine though.
