Tranfer Case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jburd, Apr 18, 2003.
  1. jburd
    jburd Registered Member
    Dec 19, 2002
    16
    Texas
    This is a dumb question, but I don't have too much mechanical experience. I took my rear drive shaft off to change a
    u-joint and some atf fluid leaked out of the tranfer case. It was a half a quart to a quart. Now I don't know how to fill it
    back up. Where is the fill hole on my tranfer case. I didn't see anything recognizable. Maybe I can't see it for all the old crud
    caked up on it. Thanks for the help.
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Look at the back of the t-case. The are two plugs. One at the bottom and one on the top.
    The one on the top is the fill plug. The size is 1 3/16". You can use and adjustable wrench if you don't have that socket. (most dont /forums/images/graemlins/smile.gif)
    If it were me, I'd drain the rest of the fluid out and change it. Prolly hasnt been done in forever. It take 5 quarts of ATF (dexron III)
    Its pretty easy.
    John
  3. jburd
    Dec 19, 2002
    16
    Texas
    Thanks for the help !
  4. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    No problem! /forums/images/graemlins/thumb.gif
    John
