Tranfercase Problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SWAMPRNR, Aug 2, 2001.
  1. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    I Have A 205 TCase That Gets Stuck In 4LOW And 4HI . The Transmission Is A 465. If I Rock The Truck Back And Forth A Couple Of Times It Sometimes Releases And Then Shifts In And Out Of 4WD Very Easy. But Normaly Requires Alot Of Effort To Get Out Of 4WD .. Any Ideas ?
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    do you have automaic or manual hubs?
    1974 Chevy Blazer Cheyanne. lots of plans for it....
    but it is on 33's now, with saggy old springs. i am in so cali if ya got any parts for me.
  3. pjwalters
    pjwalters Registered Member
    Jul 30, 2001
    11
    kansas city ks.
    my buddy has the same problem with his 205. he has a 81 k5. I did some reading and found that the 205 is actually prone to gears warping and making it reall hard to get in and out of 4wheel drive. also the 205 he has is not geared as low as the other t cases that come stock, at least his isnt.
  4. Maverick
    Maverick Registered Member
    Aug 2, 2001
    6
    Prescott Valley, AZ
    I always shift while rolling, never at a standstill, if I can help it. HTH.
    Mav...........
    <a target="_blank" href=http://fwp4x4.rockcrawler.com>fwp4x4.rockcrawler.com</a>
  5. SWAMPRNR
    Apr 7, 2001
    296
    Temple Texas
    Its A 82 With Manual Hubs.It Worked Fine In The Truck I Took It Out Of..Came Out Of My 77 That Has Manual Hubs Also.
  6. SWAMPRNR
    Apr 7, 2001
    296
    Temple Texas
    Tried To Shift Rolling And Still Stuck In 4WD. Would Not Release.
  7. Maverick
    Aug 2, 2001
    6
    Prescott Valley, AZ
    Make sure your linkage is adjusted right. Other than that, the shift rail might be worn out inside the case, That's all I can think of at the moment....
    Mav...........
