Tranfercase Question...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jeff427, Jun 10, 2000.
  1. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
    My brother Jason bought a Chevy truck (I know its not a Blazer but it is a Chevy), that has a fourspeed and a tranfercase out of a 2 1/2 ton (we think). The transfercase is larger than a 205, but it is not a 203 (it's bigger). High range is not straight through, and the rear drive shaft is lower than the transmission input, and it is bolted to the transmission (not divorced). We can't find any tags or obvious identification. Any one know what trasfercase this might be?
  2. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    How many shift Knobs are there? On the t-case!
  3. Jeff427
    May 22, 2000
    1,186
    Gladwin, MI
    Oh yeah, I forgot to mention it only has one shifter for the transfercase, it has 2x, n, 4x, and 4xlo.
  4. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    It's probably a married Timken T-221 transfer case used in 1967-1968 and maybe 1969 GM trucks. Prior to this, the T-221 was used as a divorce mount in 1960-66 GM trucks. The T-221 case has the rear output about 6" lower than the input.
    ken
  5. Jeff427
    May 22, 2000
    1,186
    Gladwin, MI
    Thanks Ken, Do you have any more info on the Timken T-221, like gear ratios or durability?
    Jeff427
    http://jeff427.coloradok5.com/
    <font color=red>Mud Dog Off Road Club</font color=red>
  6. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    1.94:1 ratio low range, good durability, parts are obsolete though. I'm sure you can get bearings and seals, but probably not gears...course finding used ones shouldn't be too big a problem. I have often thought of using this transfer case in a hugely lifted truck, as the rear output comes out 6" lower which would reduce the rear driveline angle.
    ken
  7. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    You guys know if that thing is part time or full time?
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
  8. Jeff427
    May 22, 2000
    1,186
    Gladwin, MI
    It is part time. The front drive shaft doesn't turn in 2x.
    Jeff427
