tranmission temp
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Oblin Goblin, Jun 6, 2001.
  1. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    What would be a good safe maximum teperature for a 700r4 transmission with the temperature sender in the pan?
  2. ericsoffroad
    ericsoffroad Registered Member
    May 29, 2001
    27
    wa vancouver
    working temo is 175 and to hot is 200 or at least that is what my boss says
    ABERDEEN TRANS PLACE
    are we having fun yet
  3. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I was told 180.... not sure how right that is because I never checked into that... kind of curious myself since that's the tranny I run too....
    "Suck Fumes Ford Boy"
    "I love my country, I fear my government"
    <A target="_blank" HREF=http://www.chevycagal.homestead.com/steph.html>http://www.chevycagal.homestead.com/steph.html</A>
  4. dyeager535
    26,980
    Somebody else that deals with these things more often than myself may chime in, but since (factory) the cooling lines were routed thorugh the radiator, 195 should be a "safe" operating temp. I actually believe you are getting "too hot" as you start approaching 250. You are worried about the fluid breaking down at that point.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
  5. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Speaking of this, where can one pick up a tranny temp guage/sender? Is it a standard temp guage mounted in the tranny? I guess that would work since it just measures degrees.
    Ratch
    **<A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A> What more is there to life?**
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The factory gauge on my new truck goes into the red at 250 degrees. I assume that is where the fluid will start to cook.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  7. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    When I had my 7004r it would read anywhere from about 150-190 max. I had to beat on it to get it in the 190's so I would say anything over 200 would be getting pretty hot. Hope this helps
    BlazerBoy
    http://generalblueballs.coloradok5.com
  8. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I seem to recall reading, at different times in different magazine tech articles, that most ATF starts to cook around 250deg F. Seems to be the consensus here, too...
    I also seem to recall that the fluid IN the pan has already gone through the cooler and is waiting to be pumped back through the tranny. If this actually is the case, then your pan-mounted gauge sender isn't telling you how hot the tranny truly is. Thay's why I'm getting a second sending unit, plumbing them both in the cooler lines, and wiring them through a switch, so I can see the "hot" temp and the "cool" temp. This will add immensely to my comfort level, since I have to make my 700R4 last for quite a while...
    I got my gauge from Summit. It's an Autometer Sport-Comp 2 5/16" electrical gauge. It was like $45.
    <font color=red>Click those banners and help support CK5!!<font color=black>
    [​IMG] Semper Maintenance!
    <A target="_blank" HREF=http://www.jarheadsk5.coloradok5.com>http://www.jarheadsk5.coloradok5.com</A>
