Tranny-Adapter bolt hole stripped out !
Discussion in 'The Garage' started by bigmack, Nov 5, 2003.
  1. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I looked under my truck yesterday and saw a small puddle of ATF. Under closer inspection I noticed the lower drivers side bolt that holds the adapter to the tranny was backed out. When I tried to tighten it up, guess what, the threads are stripped out. So my question is, has anyone else had this happen ? And how did you fix it. Do I just drill and tap the hole to a larger size or try to put a Heli-Coil in it ? I'm a little affraid of drilling the hole larger with it being aluminum. Just looking for advice and experiences. Thanks.
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I would try a Heli-Coil first, if that doesn't work then drill and tap it.
  3. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    J B weld a stub in it
    if all else fails
  4. bigmack
    Jan 3, 2002
    478
    Tennessee
    Thanks for the input. Now I just need to drop the t-case so I can get in there to it /forums/images/graemlins/tongue.gif.
  5. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i hear ya! the same thing happened to me a month ago, but ALL FOUR stripped out! I tried the heli-coils, but they were too short, so i ended up tapping the holes up to 1/2 inch and putting new bolts in there. it worked fine, but it was a pain dropping the t-case 3 times to get it finally fixed... Use RTV also, it might help. /forums/images/graemlins/thumb.gif
  6. bigmack
    Jan 3, 2002
    478
    Tennessee
    Thanks for the reply. Did you have to go up to 1/2"? I was thinking 7/16". Also, did you just drill out the holes on the adapter to accept the larger bolt or were they allready big enough ? Man I want to get this right, over the past year or so I have had alot problems breaking adapters, and everybody knows what a major PITA it is to find a 205/350 adapter these days.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My friend has a 350/205 adapter if you should ever need another.
  8. bigmack
    Jan 3, 2002
    478
    Tennessee
    Thanks, I'll keep that in mind.
  9. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    I don't like heli-coils. Keen-serts are the best you can get. You want to be able to service it without replacing the helicoil every time use the keen-sert.
