Tranny adapter to 203
Discussion in 'The Garage' started by bugspray, Sep 25, 2004.
  1. bugspray
    bugspray 1/2 ton status
    Jan 13, 2004
    110
    Phx, Az
    The original TH350 that came in my rig finally ate it. This will be my first swap in of the tranny (TH350). I'm not sure of the adapter situation to the t-case. Will the one on my tranny come off and bolt up to any TH350? Or is there specifically built TH350's for a 203 t-case?
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    yis, a gth 350 adpatear is unike to itself. if you r just rapo;lacing the tranie, then the adapterr will just dswap betewen the trannieys.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    dude, i think you had enough to drink. /forums/images/graemlins/whistling.gif just messing with ya. /forums/images/graemlins/waytogo.gif
    the adapter will bolt to any th350. you need to remove the np203 before you can the it off the tranny. you will need to make sure that you get a th350 with a 4wd output shaft. there is a big difference in length beteen the 2wd shaft and 4wd shaft, as long as you get a 4wd th350, you wont have a problem. (aslong as its 80 and older)
  4. bugspray
    Jan 13, 2004
    110
    Phx, Az
    How do I tell if the tranny is 79 or older?
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    actually its 80 and older /forums/images/graemlins/doah.gif, if it has a 203 or 205 on it, its most likely 80 and older
    if it has a np203 or np205 on it, then it'll work. the np208 output shaft is quite a bit longer.
