Tranny adjustment
Discussion in 'The Garage' started by hunterguy86, May 1, 2005.
  1. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    My 700R4 really jumps into gear hard when shifting into drive or into reverse from park or neutral. I was told that "the cable" probably needs to be adjusted. What does that mean. Is there anything I can adjust on this thing or do I need to take it to the tranny shop to get it done?
  2. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    You're talking about the TV cable. I messed with mine but caused even more drama so I ended up taking it into the shop. They set it up right for free so it was worth the trip.
  3. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    What is your idle set at?? Mine used to do that and it was because my idle was to high and it would put a shock load on the drivetrain, if your idle is fine then you need to get a tranny pressure guage to properly adjust your T.V cable.
  5. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
