Tranny and t-case fluid?
Discussion in 'The Garage' started by PsychoticDeadGuy, Sep 11, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    If i fill up my tranny will it and is it soupposed to fill up my t-case? i pulled my slip yoke out and all my fluid came out...my tranny was then dry...is that bad? i thought i read that they needed to be filled up seprately or something. am i missing something?
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yeah...thats bad! Rear trans seal shot by the sounds of it.
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    in order to fill up the t-case, there is a fill-plus thats 1 3/16th. only place i could find that bastard size was at sear, good old craftsman. then u gatta find a way to get the fluid in there. i guess this is only of the only advantages to have a t-case drop. i agree, ur seal is spent.
  4. PsychoticDeadGuy
    Jan 8, 2005
    753
    will this make my tranny feel bad? like not enough pressure and it feels sluggish? would that be caused by that?
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Auto trans run on fluid, nothing mechanical for actual drive (fluid operates the clutches etc) so if all your trans fluid is pumping into your t/case you'll be losing trans pressure and power.
  6. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,720
    8
    Washington State
    Could one just add extra fluid and let it go? The presure from the tranny would keep the fluid from interchanging with the tcase.... it should be ok to run any tcase on tranny fluid.. not the best but it would work.
