Tranny and t-caseswap
Discussion in 'The Garage' started by crazyrc, Feb 1, 2003.
  1. crazyrc
    crazyrc 1/2 ton status
    Jan 20, 2003
    106
    Northern Alberta, Canada
    Just wondering how much work is involved in swapping out my 700R4 and 208 with a T400 and 205. By work I mean any unforseen difficulties...tranny should bolt right up, I'm not sure about cross member and overall length.
    I'm wondering if I'll also need different drive shafts. I will be lengthening mine regardless, (going to 8"). Will the front shaft bolt up to the 205?
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    You'll need to add the electrical kickdown switch for the TH 400. It mounts to the accelerator pedal linkage and a single wire runs down to the tranny.
    I'm unsure on how the crossmember will line up. Chances are pretty good you'll need to shorten/lengthen both shafts. Is the T-case a fixed yoke?
    Rene
