Tranny blew.........now what?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, Mar 30, 2001.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    My 700-R4 finally crapped out. It's slipping, seems to be grinding, and shutters on take-off from a stop. There is fluid in it, but I think it's time for a new tranny. The question is, should I have this one rebuilt, or just have a TH350 put into it? Either way, it's going to cost me the same amount of money. I need some input here guys. See ya!
    "Don't hit me with them negative waves so early in the morning." Odd Ball--Kelly's Hereos
  2. lehtola
    lehtola 1/2 ton status
    Mar 21, 2001
    192
    North Carolina
    imho...you need to keep the th700r and have it rebuilt. if you plan on doing any over the road driving. overdrive does come in handy sometimes...even though you only get a few more mpgs...that's my opnion though.
    1990 GMC Jimmy 350/TH700R4/NP241/10 bolts, 4" skyjacker lift, 35x12.50R15 BFG All Terrains on 15x10 AR Baja's, Flowmasters.
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    I would have the 700 built to hold up to anything, very HD..
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "He who uses a winch...... Is tired of yankin!"
  4. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    My 700 is also starting to slip. How much does a rebuild usually cost. I want to get an idea before I start shopping around.
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    The 700r4 is one of the most expensive trannies to rebuild. Most places will charge you around $1000-$1800 to do a complete rebuild with new convertor...
    My friend had his done by Rossler Transmissions and it was about $1500...
    Mike [​IMG]
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    1200 to 1500... for a stock rebuild in the truck. I upgraded to Raybestos Blu clutches... extra clutches where we could muster them, vette servo, and few precisly drilled holes and filled areas in the valve body to enhance the shift. Runs awsome... but then a friend of mine is a Tranny guy and did it. I'd highly recomend keeping it and building it up... just get a good cooler
    1987 Chevy K5 Blazer- 350 TBI
  7. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    4L80e...
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if you go with a 350 over the 700 you will probably want to re gear front and rear to compansate 4 the loss of the overdrive
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  9. StoneyK5
    StoneyK5 1/2 ton status
    Jan 4, 2001
    472
    Birch Bay, Wa.
    Had mine built last Dec. and it was $1500. Mech said my engine wasn't breathing and needed a new cat. converter, so I had him replace that also. Sure made a diff in power.
    83K5 Silverado
    What was that bump?
  10. flcpl4fn
    flcpl4fn 1/2 ton status
    Jan 9, 2001
    194
    Florida
    I had mine rebuilt for under $500 and that was with a shift kit and new convertor. but that is here in fl.
    '85 Jimmy in Jax, Fl
  11. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    I drive my 700 in Drive/Non-Overdrive most of the time. No probs up to 70. I'd drop a TH400 in there if I were you. Regear? Just put bigger tires on if thats a problem for you.!
  12. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    The guy I bought my Blazer from. Had the 700 rebuilt about 9 months ago. It cost him $1695.00 to rebuild it. He gave me all the paper work because it is still under there warranty.But that was here in Calif. Where evey thing cost to much. LOL
    Become one with nature............Then marinate it..
  13. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    From Reading your bio. I would put a 400 in. But a 700 is a good tranny but it is like a woman, it can be very beautiful but you have to take care of it. If you mis treat it it will leave you.
    Will work for beer, parts and tools.
    90 Jimmy 350TBI-700R4-241-33" BFGs-10 bolts w/4.10's
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  14. bassphreek
    bassphreek Registered Member
    Feb 17, 2001
    25
    nj
    what tcase do you have...going to a TH350 my give you all sorts of problems with trying to find the right midplate adapter. and if you go to a TH400 i think the output shaft has a dif spline count, so that means a new tcase. i just got finished going through the same thing, so make sure you cover all possible problems before you start!!
    i like imports..........they make good speed bumps
  15. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Well i just put a rebuilt in my 83 after i had pretty much lost all
    but 1st gear and had some grinding noise from the converter
    area any i got the rebuilt for 850.00 with tax i rented a tranny
    jack for 20 bucks after it was all said and done it cost me about 950 and all. Doing it this way work best for me if i had
    a tranny shop do it i wouldnt have known the cost untill it was done, and when it would be done. Mine is my only ride
    it had to get done ASAP. The rebuilt has a 24month 24k warrnty not to bad. I did the pulling and putting in a day in the
    parking lot of my apt. Good thing too it snowed the next day
    Now if i had time and money i would of got the JET 700r but at 1500 or is it 2500 anyway it was'nt option at the time
    Well thats my two cents worth. good luck
    Lost? i'm not lost i'm just disorienated
  16. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    mine crapped out this week. i was callin the place today.... but their not open on the weekends... =(
    i guess ill have to wait 2 more days
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
