tranny braces??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rcpilot, Dec 7, 2002.
  1. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    on ebay someone is selling the bellhousing to motor braces for a '90 Blazer.. will these fit a '76...he doesn't have part numbers, they were ordered from the dealer. /forums/images/graemlins/k5.gif
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    These braces and mounts at the motor mount ends will only work with the HD K-case tranny housings. You will need the aluminum dust cover, too.
    The reason these will only work with the K-case is the fact there are 6 bolts to hold the dust cover to the housing.
    Non-K-case housings only use 4 screws to hold either a thin steel or plastic dust cover.
