Tranny Cooler Electric Fan.....
Discussion in 'The Garage' started by 74BBPowerHouse, Aug 20, 2006.
  1. 74BBPowerHouse
    74BBPowerHouse Registered Member
    Mar 17, 2006
    90
    Mount Angel, OR
    If I I just bought a new tranny cooler and an electric fan for it, and I mount it between the Radiator and Grill.... Im probably gonna want the fan to be pushing right? Its a push/pull fan. I know it sounds like a dumb ? but an answer to confirm would be perfect. Thanks
  2. dyeager535
    26,975
    If it's in the front, it still has to try and force the air through both coolers, which will slow it down. If there is space between the two coolers then it might be a bit better in front.
    I believe GM mounted their tranny cooler fans in the front.
  3. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Front, push.
    What temp did the factory units come on at? I know the sender was in the Pass. cylinder head.
  4. stkcode
    stkcode Registered Member
    Nov 30, 2005
    86
    Apple Valley, CA
    The aux pusher fan on my burb came on somewhere around 220....really high. I replaced the sender with a painless 185 from summit.
  5. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    I thought the main idea with the aux/cooler fan combo was to allow you to mount it anywhere. You are not restricted to putting it in front of the radiator and blocking airflow. You can put it anywhere its protected and the fan will still make it work.
  6. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Exactly.
  7. 74BBPowerHouse
    Mar 17, 2006
    90
    Mount Angel, OR
    I guess i didnt mention its going on a 74 with a BB and th400.... im mounting it in front of the rad and the fans going to push and be ran while the ignition is on. thanks for the help
  8. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Another option, run it on a manual switch. If the temp is too high for your liking, flip the fan on. You could run a temp switch if you like things auto.
