tranny cooler fitting on rad.
Discussion in 'The Garage' started by surpip, May 7, 2006.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    anyone know what size these are? 1/4 npt is to big, i need a adatper from what ever size they are to -6an
  2. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    I thought they were 3/8" flared fittings or maybe 5/16" flared fittings. not sure what the threadsize/tpi is for either.
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I think they are inverted flares. They're the same as rear brake lines.
  4. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,008
    197
    Santa Maria, CA
    5/16 inverted flare.
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    so is there a -6 to 5/16 inverted flare fitting?
  6. JDNobodi
    Oct 9, 2002
    3,008
    197
    Santa Maria, CA
    Hmm, good question. You may have to adapt the inverted flare to pipe and pipe to AN. I believe they make 3/8 inverted flare to -6AN for power steering.
    Edit- I'm going by tubing size. but to buy an adapter, you have go by fitting size. Messure your fitting and pick your adapter if they make one.
