Tranny cooler is in.
Discussion in '1982-Present GM Diesel' started by FWP, Sep 16, 2004.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Put in a 28K B&M today. Bybassed the radiator cooler/ warmer completely. Here are some numbers before the install...
    Unloaded, 6-7% grade for 5 miles (Black Canyon City to Sunset Point)
    RPMs 2600
    65 MPH
    3rd gear on Th400
    EGT 1050
    Boost 6 psi
    Coolant 200
    Oil temp 210
    Tranny temp 205, sender is in the pressure port.
    Will add more, post-cooler install, next run...
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    tranny temps dont look that bad. /forums/images/graemlins/confused.gif
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Basically, I just wanted to start a baseline, that said...
    I didn't have a tranny temp gage while driving the same stretch of highway, loaded, pulling my Blazer, but here's some numbers for that. I'll guarantee that alot of the heat came from the tranny. Also had a questionable clutch fan, and a dinky Stant thermostat at the time. Put in a Hayden clutch and a Stant 6.5 thermostat *195(oops- my original post said AC Delco t-stat- that's the next move) since these numbers...
    RPMs 2800
    25 MPH
    1st gear on Th400
    EGT 1050
    Boost 6 psi
    Coolant 230
    Oil temp 240
    Tranny temp ???
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Interesting, different stretch of road, mild 2-3% grades for 50 miles, pulling 10,200 lbs.
    RPMs 2800
    45-55 MPH
    2nd, 2nd-over and 3rd, depending
    EGT 1000-1050
    Boost 6-7 psi
    Coolant 215 at the hottest
    Oil temp 220
    Tranny temp 180-ish, (VDO gage has a small 150-200 range)
    Might need to install the Kennedy dual t-stat setup.
  5. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Thats a bit odd, seems kinda in the high temp range. then again, you are towing some massive weight.
    I'd check the condition of the radiator, it might be a little clogged or something. Also try some water wetter. Stuff works good.
    (BTW, aint those RPMS just a tad bit on the high side?)
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Radiator is ok. Pulled it last month, had it sealed and pressure tested. Need more coolant flow I think.
    RPMs are good, top of the HP curve (according to Banks anyway) If my thinking is right (who knows /forums/images/graemlins/screwy.gif) I'm thinking 2800 for HP juice, 2000 for torque and fuel mileage.
  7. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Unless I already have the upgraded water pump- I looked at how much was pumping out of my heater hose... it is ALOT.
    I wish I could find a picture of a stock 6.2 water pipe.
  8. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    RPMs are good, top of the HP curve (according to Banks anyway) If my thinking is right (who knows ) I'm thinking 2800 for HP juice, 2000 for torque and fuel mileage.
    Pretty good ballpark Fred. Max fuel mileage unloaded would be around 1800 rpm though. Max hp would be between 2800 and 3600 rpm (governed upper limit)
    Rene
