tranny cooler line size
Discussion in 'The Garage' started by HELLBENT DESIGNS, May 23, 2005.
  1. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    hi does anyone know the pipe thread size of the fitting for a th350 transmission?, i need to order adapter fittings thanks :D
  2. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
  3. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    it should be 3/8's i believe... t400 and 700r's are the same and those are 3/8's npt iirc...
  4. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    i tried a 3/8 and it was too big1 i was hoping somone would say oh it's 1/4" that's my guess :dunno:
  5. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    honestly, i'm going on what i remember them looking like from last spring.. :o they might may very well be 1/4... actually now that i think about it, 3/8's is pretty big compared to what i remember putting in when i went with Endura fittings and #6...
    thought i had a link to a list.. hmmmm, wait, here it is... http://www.tciauto.com/tech_info/cooler_fittings.htm
    looks like i was wrong, t400 and 700 are the same at 1/4 and it says 350 is 1/8.. boy that seems small for a tranny line...
  6. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    wow i would think they would be larger! :yikes: thanks alot for the info :waytogo:
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    5/16" tubing is for trannies
    3/8 was for 4 bbl carb fuel feed
    5/16" also was for 2bbl carb fuel feed line
    3/16" is front brake lines and rear axle tube lines-= after the rear hose split block
    1/4" for rear frame line all way from the rear brake m/c port
  8. louied
    louied Registered Member
    Mar 19, 2002
    84
    Philadelphia
    that is a great reference breakdown, i always get confused when trying to remember.... Thanks !!
  9. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    just to let anyone know that's thinking about a braided line swap. i ordered the 1/8" pipe thread fittings for my th350. no worky :mad: too small! must be 1/4" TCI's info isn't complete :dunno: the tranny i have is the standard th350 to 203 nothing exotic.
  10. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    i thought that sounded small... sorry for the misleading link... :( i feel bad considering i've done the swap with my 700.. shoulda remembered...
    what brand fittings you running?
  11. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    no problem! i usually run AEROQUIP or EARL'S sometimes summit racing's stuff if it works :D
  12. Wes Harden
    Wes Harden Registered Member
    May 28, 2005
    29
    Southern Califorina
    question
    Are you asking the thread pitch and dia of the cooler line holes in the alum case
    or the size for the tube nut ?
    I confused cuase 1/8 is what you use for oil sender.
    Wes
  13. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    the npt size of the case... it should be 1/4, like the 700r4....
  14. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    What type of plumbing/hose would one ask for if running soft transmisson lines ?
    I know the high temp rubber stuff is not good because of fire risk, but could I run all the special braided hose instead of my poorly routed metal line ?
    Blake
  15. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    i run Russels #6 steelbraided Proflex with fullflow fittings...
  16. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    iirc NHRA regs are less than 24" of rubber line on vehicle? the more rubber line the more risk of leaks/fire. factory steel lines work fine for 99% of rigs, braided lines for trannys may be overkill :dunno: 6an line should be fine for trans lines. i was most concerned about chassis flex and fatigue with steel lines as well as aftermarket cooler options so that's what made me decide on an stuff :D
