tranny cooler lines
Discussion in 'The Garage' started by HELLBENT DESIGNS, May 20, 2005.
  1. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    hi i am planning my tranny cooler line routing. i plan on using an fittings with #6 hose. i purchased a b&m suppercooler 28,000 gvw. it has the 1/2" npt fittings so i can use the an stuff. question is can i just run the cooler lines to the b&m cooler? i have read about going through the stock cooler in the radiator first to get the fluid up to temp quicker, but i will not be driving this in winter (as of now) is just using the cooler a bad idea? it would make hose routing so much simpler. :confused:
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    mine is run just thru the cooler. i'll be rerouting back thru the rad first soon... it takes a long time to get up to temp and in the winter its rediculously long... it'll run 160 eventually these days...
  3. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Mine runs straight thru the cooler as well and I havn't noticed any ill effects from it either, but then again the bitch won't start below 30 degrees :blush:
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Proper operating temps are necessary to evaporate off the moisture. good operating temps are like 160-200, with 175 apparently being the "optimal" temperature. (I say apparently, because that is the general consensus on the net).
  5. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    Especially since you live in Montana, I would leave the factory cooler installed. I just happened to be reading about tranny coolers in the TH400 book, and he specifically said to leave the factory cooler installed in cooler climates. Actually helps warm the tranny up in the winter. Like previously said, the tranny needs to be warm enough to evaporate the moisture out.
