Tranny Cooler Lines
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by clarkekent, Mar 24, 2003.
  1. clarkekent
    clarkekent Registered Member
    Sep 26, 2000
    69
    NY
    Where can I get new tranny cooler lines? Mine leak like a #@^&%&*^!!
  2. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    LMC has them listed. $30-80 per set depending on what you need. Have you checked the local NAPA?
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Fine Lines makes the best hard line repops of any of the companies making them. I'm sure that the places like Golden State, LMC, Chevy Duty, etc. buy from one of the big three hard line benders (Fine Lines, Classic Tube, Inline Tube).
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    If You have a Good Hydraulic Hose Shop in Your area, most of them have Steel tubing, and Fitting's at a fraction of the cost. You'll need Your old Line's as sample's though. /forums/images/graemlins/grin.gif
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    all thjey are are 5/16" brake lines, easy to do, just go to store and get lengths of 5/16" steel tubing, the fittings are same threads, flare kit is cheap to rent and easy to do. save yourself some money, i dont know why everyone thinks that the only way to have lines is to buy prebent ones, crazy...
    good luck
  6. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    R72K5 That's what I was referring to, but most People don't have a Tubing Bender. Or a Flaring Tool.
  7. 71blaz
    71blaz Registered Member
    Aug 1, 2002
    86
    southwest colorado
    I replaced mine with good quality hose and the correct fitting. The cost for the hose fittings and clamps was under $20 @ the local parts store.I was then told the steel lines help dissipate heat so I added an additional trany cooler infront of the radiator. Seem to be working great /forums/images/graemlins/pimp1.gif
