tranny cooler location
Discussion in 'The Garage' started by blazinzuk, Jul 13, 2006.
  1. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Hey guys I need to mount my tranny cooler before I run my truck and I need some opinions do you think location 1 or location 2 would work better for my cooler. Please give reasons
  2. 1BadK-30
    1BadK-30 1/2 ton status
    Feb 6, 2005
    817
    Phoenix, Arizona
    i have mine in 2 ran it with my 700r4 with a 1200 dollar hauling upgrades have had the 1ton suspension inches off the ground has held up fine.
    with your setup i dont see the difference in which way you mount it allthough in number 2 it could block some airflow to the radiator but im not sure how much of a restriction it would cause.
  3. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    I was thinking the fan might help it pull some air in location #2
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    you won't have any air flow issues with it mounted in front of the radiator, they are designed to let air pass through them:rolleyes: ,
    the only real issue would be if you had air conditioning, wouldn't let the condensor cool as much. but if your running a decent cooling system, and a strong fan clutch, you won't have any problems with it right in front of the radiator.
  5. sweetk30
    Nov 1, 2004
    25,543
    539
    horseheads , ny 14845
    i would do air flow and before stock inline cooler. so all the extra heat is lost and the stock cooler will keep it at a more consistane temp and in cold temps it will warm the fluid faster.
  6. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I'm running mine in position 2. I haven't had any problems and it's been in there for the past 3 years.
  7. stkcode
    stkcode Registered Member
    Nov 30, 2005
    86
    Apple Valley, CA
    I would go with position 2 as well. As long as the tranny cooler isn't too big, their shouldn't be an engine cooling issue. I originally had a 26k cooler, which was restricting air flow a bit too much, so I dropped to a 22k cooler instead. I ended up spacing the factory aux pusher fan out for clearance for the cooler.
  8. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yeah, No.2. More airflow and use the stock cooler too if possible.
  9. balterbuilt
    balterbuilt 1/2 ton status
    May 10, 2004
    385
    Santa Rosa
    i don't have a roof so Irun mine in the back
  10. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Mine's in No.2 also.
  11. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    pic doesn't show much info. Is your fan a stock mechanical or electric? My vote is to put the cooler where the fan can pull air threw it... where ever that is. Driving on the interstate, you'll get plenty of air no matter where you put it up front... but when crawlin' it'll have to be close to a fan to work best. Location #1 would be fine if some sheetmetal got cut and a fan added.
    j
  12. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Mine is in Position #3 Positioin #2 is my PS Cooler:D
    Ira
  13. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    Yah this was my thought too, it is a newer clutch fan works good. Position 2 it is
    thanks guys for all the input
  14. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Id go location #2, thats where I have mine, I have the biggest B&M cooler, the 11x11" stacked plate, I think its 29 or 30k gvwr. Anyway, I completely bypassed the factory cooler, little extra stress off engine cooling, and around here it dont get cold enough to worry about overcooling.
  15. az88k5
    az88k5 1/2 ton status
    Oct 14, 2004
    258
    Prescott Valley, AZ
    I run a Perma-Cool on my 88k5 with a 700r4:
    • Maxi-Cool Six Pass cooler
    • Large 5/8" aluminum tube and 1-1/2" wide aluminum fin design
    • Coil size: 1-1/2" x 10-1/2" x 14"
    :thumb:
  16. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,801
    387
    Clayton Del
    Go for #2 , also don't use the factory cooler it's never made any sense to me to run trans fluid through the hot coolant to try to cool it down .
