Tranny Cooler questions...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ddragggon, Nov 27, 2001.
  1. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    first off, let me say I hate almost everything about Automatics, except for the inherent ability to just put it in drive and go, and the ability to eat a hamburger in bumper to bumper
    traffic...
    with that said, the @%#&in' tranny cooler in my 73 K20 sprung a nice sized leak... I need to replace this thing, and after gazing in horror at the prices they have listed for them at the
    auto parts store, one of my friends old ideas came to mind. I figgure I'll check here before I try it on my own, but what kind of problems could be associated with me going to a junkyard,
    getting an AC condenser from a wrecked jap mini truck, and using that as the tranny cooler instead? I figgure it'll cost less then the 30-70 they want for a tranny cooler at the auto parts
    store, and offer roughly 4 times the cooling area. I've heard its possible to `Cold Shock' an automatic by over cooling the tranny... is this true? or is it unfounded?
    I need to get this fixed ASAP, and any info would be appreciated....
    thankyou in advance,
    -Rich
    My truck isn't ugly, you have a skewed sense of beauty
    <font color=blue>2007 Ford XLS++ intrepid Ram Superduty 7000 R-type's suck</font color=blue>
  2. dyeager535
    26,976
    You CAN overcool an auto tranny, but typically they run so hot, its hard to do. As long as the cooler wasn't too big, can hold the pressure, (don't know squat about AC systems) and flows good, I don't see a problem. But if you are at the wrecking yard looking for a used AC condensor, why not just look for a used tranny cooler? : )
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  3. Ddragggon
    Apr 25, 2001
    2,657
    I COULD look for a used trany cooler, but the way I see it is I may as well get prepped up and ready to go for dumping in a T400, with an overpowered 454 behind it.... :-P
    I'll prolly see if I can find one of those super heavy tranny coolers at a junker before I put an AC cooler in there.... the AC cooler can hold up to the pressure of the AC system, so it makes sense that it'd be able to hold up to the transmissions pressure... truthfully, I suppose I could go rip the AC condenser off of my parts suburban, and have no problems at all... it'd fit perfectly in the K20 too, hehe come to think of it, the parts burb has an HD trailering T-cooler in it....
    I gotta go take inventory of that thing sometime soon....
    -Rich
  4. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    My '79 came with an external oil cooler. Maybe you could find one and clean it out real good and use that?
    Don't hit me, Mr. Moderator... I'll go back on topic... I swear![​IMG]
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer>www.geocities.com/muddin4fun79blazer</a>
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I got one of the large "Long" stacked plate coolers for $10 (IIRC) out of a local yard. I also got a smaller one (stacked plate) to use as a PS cooler.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  6. Piranha300
    Piranha300 Registered Member
    Jul 1, 2001
    45
    Nebraska
    I say just spend the $ for a tranny cooler and be safe.
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    How cool is TOO cool? my return temp is about 120-130 during normal driving during the winter. It gets to 160 if I push it. During the summer it runs 160 normal - 190 if I push it.
    My Chevy isn't broken, its just out of gas.
  8. dyeager535
    26,976
    This has been covered extensively on here before, but IIRC, optimum temp was somewhere in the 190 low 200 range. Don't take that as gospel, but since tranny temp could, ideally, match engine temp (in a stock vehicle, since radiator cools the tranny) I can't imagine 195 would hurt anything.
    I'm slightly amazed that yours runs at 120..that jsut sounds WAY too cold.
    Wait for others to chime in : )
    Dorian
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You want your tranny fluid to get hot enough to fully evaporate any water that condenses in the tranny. Moisture and tranny parts don't get along with each other. [​IMG]
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    That is the return line temp off the coolers. The tranny itself would be hotter. From what my tranny guy told me I would guess my tranny runs at about 180-190 or so.
  11. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    I heard 150 is optimum after that the life is cut in half for every 15 degrees higher you go. Summit sells a tranny or oil thermostat for like $40 run you line through the radiator and then to the thermostat if it is over 160 degrees it will send it to the tranny cooler, so there is no such thing as overkill on your tranny cooler and the tranny still warms up fast
  12. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    There most definatly is such a thing as overkill in a trans cooler. You need to have the tranny at temp for all the above mention reasons.
    DO NOT overcool your trans, or you'll be looking for a new one quicker than you might like...
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    <a target="_blank" href=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</a>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s
  13. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    There most definatly is such a thing as overkill in a trans cooler. You need to have the tranny at temp for all the above mentioned reasons.
  14. hammer
    Aug 29, 2001
    449
    Binghamton N.Y.
  15. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    clicky! <a target="_blank" href=http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=27058&amp;prmenbr=76&amp;lastcat=2624>Remote Oil Thermostat</a>
    <font color=red>1987 Blazer K5, 4" Rancho Lift, 33" BFG AT, Dual Battery setup, AND MORE TO COME [​IMG]
    Was that a speed bump? No, just a Rice Rocket </font color=red>
  16. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    I'd just drop the bucks for the proper after market cooler and be safe. $70 or $80 is still cheaper than a new tranny.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  17. hammer
    Aug 29, 2001
    449
    Binghamton N.Y.
    clicky <a target="_blank" href=http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=27058&amp;prmenbr=76&amp;lastcat=2624>just trying out how to clicky to oil cooler thermostat</a> thanks chris
