Tranny cooler suggestions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BillyBob, Sep 27, 2000.
  1. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    I know, this has probably been on the board a million and a half times. But, I wanna get a few reccomendations for a tranny cooler. I think my 700R4 could benefit from one. I was thinking, since I'm gonna have 35" tires in the future, I should get one that is around 19,000 - 24,000GVW? I dunno much about tranny coolers, but it's best my 700R gets one before I get bigger tires and possibly a shift kit in it. I don't tow anything with the truck, and I do a mild amount of muddin. Nothing hardcore or anything. Any suggestions on what size and brand I should get?
    http://billybob.coloradok5.com
    It's all fun 'n games, till someone gets stuck.
  2. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I have a built 700R...I run a Hayden...the bigger the better...it's crucial for a 700R, built or not...if you're gonna rebuild yours...Jet Performance sells their upgrade in kit form...or you can buy one outright for $1500...the difference is night and day...best money I have spent so far...JD
  3. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    K5 is right, the bigger the better and Jet has a wonderful 700R4. 1500 is about the same price that you could get yours rebuilt for at a good rebuilder in your town after they do all the upgrades and if you have a local mechanic that you trust and will give you a good warranty then I would keep my money in town, if not, buy a JET and do the labor yourself. Also, when rebuilding a transmission, any transmission, this is to everybody on the list who reads this, change the front T-case seal while they are seperated! they are only a few bucks and it will save you a headache down the road.
    Dan
    <font color=red>get involved with land issues or lose the land</font color=red>
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have a 18000 gvw trans cooler on my 89 with a 700r4. It works good for me. I tow my ski boat lot, did a 1000 mile tow in the heat of the desert this summer. Also do a lot of 4 wheeling. No overheat problems. Had the pan off the trans a while back and it was clean as a whistle. I change the fluid every year(10,000mi).
    700r4s last much longer if the fluid is changed often. And a cooler is a MUST have. If you are going to run a large cooler(24000+gvw) and live in a cold climate you may want to block it off with a piece of cardboard in the winter. Or add a thermastatic controll bypass valve.So the tranny fluid will be able to reach its normal operating temp when its very cold out.
  5. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    I have a 19,000 GVW trans cooler by B&M on my '89 and it is more than adequate. They are under $100.00 Like it said above, it's a must for a 700R4.
    '89 K5 Silverado 4" lift w/BFG 33's
  6. 89K5
    89K5 1/2 ton status
    Jun 14, 2000
    134
    Maryland, PA on Weekends
    Have a cooler on mine too. 700R4 has 65,000 miles on it, 40,000 of it with 35's. Installed B&M shift kit. Stills shifts nice and crisp.
    While you're a it, its a good idea to install a drain plug kit. Big help. I change fluid 2x a year and the filter 1x. It saves me from having a big mess.
