Tranny cooler
Discussion in 'The Garage' started by 1979jimmy350, Jul 13, 2005.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    I just bought a tranny cooler and was wondering what the best way to mount it would be. It came with the plastic things that you are suposed to poke through the raditior. I don't like the idea of putting any thing through my raditior. Are these plactic things ok or are they complete crap
  2. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    They r ok for mounting the coola n the wind......
  3. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    they work good for mounting but leave a little tail on them dont clip them off flush if you ever have to take them off and put them back on youll never get it and have to make a trip to town to buy new ones they was cheap but an inconveinance cuz your rig will sit there while you bum a ride to town
    balzer
  4. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    if you want to develop leaks, they're good... ;) they have a tendency to saw thru the tubes over time...
    if you can figure out another way with brackets, etc, you'd be better off...
    i used thick rubber pads and some stainless tabs to sandwich the endtubes. its worked flawlessly...
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yeah. take the time to make a bracket. Those hard plastic mounting tabs will cut thru a radiator tube over time. Espically bouncing around on trails.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The best place that I've found for those plastic zip-tie type holders is in the nearest trash can. Fab up a decent mounting bracket. You'll be glad you did! :cool1:
  7. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    Used those plastic things once, but never again. Make some brackets. You can get angle or flat stock from the hardware store.
  8. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    radiator saws...
    I'd never use those plastic radiator ruin-ers!.I noticed my diesel truck has them,and I hope they dont saw thru the core of THAT radiator! :eek1: :eek1: 400 bucks if they do! :mad: I'd use a real bracket made of steel!--I have used the metal strapping you can get at Home Depot or Lowe;s,its about an inch wide and 1/16-1/8 " thick,and has holes punched in it every inch or so..have to get some and re-do my truck before I need another radiator... :doah: :(
