Tranny cooler
Discussion in 'The Garage' started by sandawgk5, Nov 19, 2005.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I have a 700R4 with the factory cooler and I am looking to replace it with a stacked plate design so I can use my existing cooler for my Powersteering. My question is is this the cooler I need it is 24000GVRW cooler.
    B&M Cooler
    Ira
  2. mrhoes
    mrhoes 1/2 ton status
    Jul 20, 2002
    123
    Austin, Texas
    get the biggest cooler you can afford, tranmissions dont like heat the bigger the better.
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    BELIEVE THAT!!
    I used the stock cooler AND a 30,000 in the wifes truck after the NEW tranny went in!!
  4. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
  5. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    You can pick up the same cooler with the thermostatic bypass for an additional $10 on ebay. I put this one on my truck and it works great! Just a thought... :D
  6. sandawgk5
    Oct 28, 2003
    6,881
    Thanks for the input guys it appears that Longs is the same company that makes B&M stacked plate coolers. I got this one Tranny cooler
    It has a thermal bypass not sure if I will use it but I prolly will I will plumb it through the stock cooler in the radiator then through this cooler. I am taking my factory aux tranny cooler and am going to use it for a powersteering cooler to help with my hydroboost plans.
    Ira
