tranny cooler?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by emoo99, Apr 3, 2003.
  1. emoo99
    emoo99 1/2 ton status
    Jan 16, 2003
    494
    Washington
    i have a funny question.. i got my truck a few months ago, put some new 33's on but still have 3:08's i was wondering how can i tell if i have a tranny cooler already on my truck?,, there's this little radiator thing right behind my grill (infront of the radiator).. is that a tranny cooler or could it be something else?.. i took a drive up to the pass yesturday and it sucked hardcore with my gears.. i'm really concerned now and looking for some 4:56's but in the mean time i want a tranny cooler (unless this think i'm seeing behind my grill is already one? /forums/images/graemlins/confused.gif)
  2. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    Could be oil cooler, could be AC condenser, could be tranny cooler.
    Trace the plumbing on it -- if the lines go to the tranny, bingo.
    Factory tranny coolers, however, are *built into* the radiator -- which some people loathe, as it will only cool the tranny fluid to the temperature of the radiator.
    Regardless of your gears & such, an external, separate tranny cooler WILL help your tranny live longer.
    -- A
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    tranny cooler:
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    If it looks like a factory setup then chances are it's an oil cooler. Like Dremu said, follow the lines to their source.
    R72K5- Just so you know, there are two styles of auxilliary tranny coolers on the market. The one you posted is a tube-fin design. Most people opt for a stacked plate cooler nowadays, which looks just like a miniature radiator.
  5. Dale fan
    Dale fan 1/2 ton status
    Dec 5, 2002
    167
    Arkansas
    My 90 has a factory tranny cooler behind the grill. It was part of a tow package.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    uhmm,.,.. i said stock factory, my pic is of a 78 one, ive come across alot of them, im not sure what you are talking about as far as stacked kind or whatever
    emoo is talking about stock type and thats what i took pic of
    thanks
  7. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I have an 82 and I have a setup like they explain at the top and I traced the lines and they run to my tranny so all you can do is trace the line ....Jason /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/pimp1.gif
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    all GM vehicles with auto trans have at the minimum the integrated style trans cooler radiator, the aluminum aux cooler i posted pic of is the optional add-on style cooler avaialble option from GM for many years, vehicles with this cooler also still have the passenger side integrated cooler in the rad tank
  9. Can Can
    15,552
    136
    HMMMMMMM...... good info. I wasn't aware that at one point in time the optional factory tranny cooler was a tube fin design. I've never seen one like that before except as an aftermarket add-on.
  10. emoo99
    Jan 16, 2003
    494
    Washington
    Thanks Guys i'll check that out.. I was also looking for an external one if this i'm looking at is just an oil cooler, and i found some on JC Whitney for around $160, i guess i want to go with aluminum cause they cool faster but what else do i need to know? I figured the bigger the better, and what the towing rate is rated at? but is that all?
  11. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Must be my eyes, but that pic is of a tube-finned and not a stacked plate.
    THey claim a stacked plate is 30% more efficient, but I've personally never checked.
    Im putting in a third tranny cooler- In radiator, factory aux, and a 10,000 Stacked plate. Why so many? My theory is , if your tranny is heating up, it can only move so much tranny fluid- The max that the pump can throw out. Even if you have a 50,000 cooler, it still cant move faster than whatever its max through put is. (and if you've ever removed the hose and put it in gear just to see, its not exactly like a garden hose). About a quart a minute is my rough guestimate. on a large cooler, you could probably squeeze in almost half a quart. I figure that with my combination, I should be able to get that quart to cool a fair amount before heading back into my tranny.
    just my unsubstantiated, uneducated two cents. Im sure if someone was scientific enough, they could put a temp probe before the start of the cooler, and a temp probe in the return line of the cooler. That would be the most definitive source of effectiveness.
  12. Lane
    Lane Registered Member
    Mar 19, 2003
    13
    Montevideo,MN USA
    Emoo99-
    Find out if your truck does indeed have and external trany cooler besides the one in the radiator( all you have to do is follow the lines or disconnect one and if its redish then its a trany cooler) If it is a trany cooler then you may not need a new one. Get a Trany temp guage and see what she is runniing at. A trany Guage is a must if you are going to be working the truck at all.
    Hope it works out for ya
    -Lane
  13. Can Can
    15,552
    136
    I'm pretty sure that's what I said...... /forums/images/graemlins/confused.gif
  14. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    doh, my bad! Though Im almost certain mine is tube finned and not stacked plate. /forums/images/graemlins/frown.gif Thats why Im adding one. /forums/images/graemlins/smile.gif
  15. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    you can get a 24K GVW stacked plate tranny cooler from summit for about $50.
