Tranny cooler
Discussion in 'The Garage' started by pplblazerdude, Jan 31, 2004.
  1. pplblazerdude
    pplblazerdude 1/2 ton status
    Jul 18, 2002
    242
    Kingsport, Tennessee
    Im getting ready to rebuild my motor and it will have a good amount more hp an tq and i was wondering if i need to get a aftermarket trans cooler and if i do do i need to use the aftermarkt one and the stock one i already have.
    Clint
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I would get one regardless of engine build. The bigger, the better!
  3. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    700r4 need to stay cool! Get a good trans kooler!
    Bill
  4. pplblazerdude
    Jul 18, 2002
    242
    so would i still use my stock tranny coller or not.
    Clint
  5. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Not if you got a really decent aftermarket kooler with a fan!
    Bill
  6. pplblazerdude
    Jul 18, 2002
    242
    if i got one it would not have a fan. Those are to expensive.
    CLint
  7. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I use the stock cooler and auxiliary cooler - in my opinion, that's the way to go.
  8. mr_fujisawa
    mr_fujisawa 1/2 ton status
    Sep 1, 2003
    288
    SF CA
    i got this one for my k5. . .it comes highly recomended:
    tranny cooler /forums/images/graemlins/woot.gif
  9. fly_n_hi_yukon
    fly_n_hi_yukon Registered Member
    Jul 8, 2003
    44
    Strange Range, MI
    I would run it in series with the factory cooler inside your radiator. That's what I did and it worked mint.
  10. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    CLint
    Not as expensive as a fried tranny!! Just ordered a B&M one with a fan from summit. Keeps it below 160 supposedly! /forums/images/graemlins/thumb.gif
  11. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Run it in series with the stock cooler. Normally you would run thru the aux cooler first then the radiator cooler. Some go the other way. Get the B&M crossflow type.
  12. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    If you don't run through the factory cooler you will cook the tranny in the summer and run it too cold in the winter. It needs to go through the factory cooler either before or after the aux. cooler.
  13. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    I have mine running throught the factory coller and auxillary cooler.
    Bill
  14. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Bill
    From this reply I was going to bet you did not run it through both coolers.
  15. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    I should have clarified that statement. Not if you have a factory external cooler. My mistake /forums/images/graemlins/eek.gif!
    Bill
  16. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Get the biggest one you can find, run it thru you aux. cooler first, then your factory cooler. Cold tranny fluid is as bad as burn't tranny fluid.
