Tranny Crossmember questions
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Rusty68, Apr 3, 2003.
  1. Rusty68
    Rusty68 1/2 ton status
    Jan 22, 2003
    116
    Elko, Nevada
    On my other 68 project I installed a th400/205 set-up. The 4x4 frame I bought did not come with a tranny crossmember so I slid one from a 77 Jimmy under it. It looked like a good fit and it bolted up fine with the factory holes in the frame. But I had to move it like 3 inches back to fit the 400 trans. Anyways, I am wondering if the first generation c/m were different then the 73- up style. Mostly because my transfer case is about 1/4 inch from smacking the floor of the cab. I thought I could beat this by putting in like 1" inch body lift if I have to. Thanks for any pointers.
  2. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    Did your '77 have a 205 or a 203?
  3. Rusty68
    Jan 22, 2003
    116
    Elko, Nevada
    a 203 and a th350, hmm didnt know there was a difference
  4. '72brett
    '72brett 1/2 ton status
    Dec 3, 2002
    166
    northwest Iowa
    yes, big difference... a th350 in a tranny, and a 203 in a transfer case. I think what u meant to say was you didnt know there was a difference from a 205 to a 203. The 205's have lockout hubs, and the 203 is all-time 4X4. Not sure what the dimensions are different, but you sure wouldn't want a 203 in place of a 205.
  5. Rusty68
    Jan 22, 2003
    116
    Elko, Nevada
    Yes I did know the difference between the cases. I was saying that I didnt know there was a difference between the 203 and the 205 crossmembers. When I was talking about the th350 trans I was just saying that is what was attached to the 203 when I pulled the crossmember in case in mattered. The crossmember located the tranny/case centered in the frame so no problem there. I am just concered that the case is so close to the bottom of the cab. So if there was a height difference I should know about between the 1'st and 2'nd generation. If there isnt, then I will just add a 1/4 inch shim to drop the case and add a small body lift to clear it up top. Ah, the joys of trying to install somthing that was never there in the first place:)
  6. '72brett
    Dec 3, 2002
    166
    northwest Iowa
    Oh, OK, please forgive me /forums/images/graemlins/blush.gif I see what you are saying now, and I have no idea on what the difference would be.
  7. Anthony72K5
    Anthony72K5 Registered Member
    Mar 17, 2003
    20
    A 203 is much longer than a 205 I think.
    My '72 doesn't have a tranny crossmember, although I have no idea if this is how it left the factory or not.
  8. Rusty68
    Jan 22, 2003
    116
    Elko, Nevada
    The crossmember is not bolted to the tranny itself, but to the adapter inbetween the 2 cases. I think the setup I have now is going to work.
