Tranny fluid change interval
Discussion in 'The Garage' started by johnathan, May 27, 2006.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    How often do you guys change your tranny fluid?
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    That depends so much on how you drive and your type of use. I change mine around every 10,000 to 12,000 miles which is way more frequent than the factory service interval. If you're lots of towing or slow heavy wheelin you may want to change it even more frequently. If you don't have a cooler you'd want to change it more than someone with a good cooler.
    If you're not having problems with it just keep an eye on the fluid level and check the smell and colour occasionally.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    My truck leaks out 3 qts of tranny fluid into the t-case every time it sits for more than a week. I just pour in 3 more qts and drain the t-case.:crazy:
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    When I drove for a limo company, their mechanic changed the tranny fluid in the Town Cars every 20Kmi, or whenever a car had a transmission-related gripe written by a driver.
  5. stkcode
    stkcode Registered Member
    Nov 30, 2005
    86
    Apple Valley, CA
    I change the fluid every 25k miles or so and do moderate towing...but I also have a 22k gvw aux cooler. Besides the good advice in the above posts, also make sure to check the fluid for metal shavings....it could mean it's not far from having problems.
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    everytime i change out the transmission :D :p:
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Bought my '91 S-Jimmy brand new in 1992. The 700R4 in it now has 167K miles on the clock and still has the ATF in it that it left the factory with. :yikes: It did much of its first 100K in Houston, then the rest in Colorado, so it's seen some serious tempreature extremes.
  8. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Once a year wether it needs it or not. Change it in the spring just before towing season
  9. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    OK, let me ask this how do you change the fluid? Do you just drop the pan and refill or take it to a shop and do the "power Flush" thing ??
  10. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    As I do mine quite frequently I drain the pan (I fitted a drain bolt) only.
  11. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    You can flush it at home,just takes about a case of fluid.
  12. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I change mine every 12-15,000 miles
  13. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    wow, I'm the guy gets paid to do it and I do it less than some of you guys :haha:
    I recommend them at 30k or when the fluid looks pretty brown.
