Tranny fluid in power steering?
Discussion in 'The Garage' started by Desert Rat, May 15, 2003.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Ok, I was working on the power steering pump in one of my Blazers I bought and the fluid that is coming out of it looks to me like ATF. I'm assuming from other threads that I researched that this is ok. But, should I want to swap in PS fluid, is there any problem with them mixing?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    naw you can mix them they are basically the same thing /forums/images/graemlins/thumb.gif
  3. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    im betting that red stuff is that lucas PS "quick fix" stuff. those r my thoughts n e wayz
    NITRO
  4. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    on the WTO website, Matt says that he has noticed ATF will dry out and cause seals to crack. JFYI... ive used it before, but im using Synthetic stuff now.
  5. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    your power steering is basically a hydraulic pump that runs a hydraulic assist cylinder inside youe steering box. So power steering fluid is basically hydraulic fluid. Automatic transmissions run on basically the same principle with the torque converter acting as the hydraulic pump turning the input shaft. So transmission fluid is basically hydraulic fluid. Now with a precision item like a tranny I wouldn't run anything but tranny fluid in it as it hits very high temps. I have run tranny fluid in my power steering, hydraulic dump beds, our monument trucks crane and liftgate and have had no problems. I have also run tractor hydraulic fluid/gear oil in the above items with no problems at all. The difference being the tractor fluid is thicker and needs warmed up in winter before it will work right where tranny fluid is thinner so it works well in winter but if your cylinders are worn it will leak. Sorry to ramble.
  6. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    I just run good quality A.T.F. in mine, has about 300,000 mile's on it, and no problem's yet. /forums/images/graemlins/eek.gif
  7. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    The difference between the two is that ATF is kinda like a detergent which may go through the seals faster than actual ATF fluid...
  8. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Most P/S fluid w/ stop leak has a red dye in it.
