Tranny fluid in the t-case adapter
Discussion in 'The Garage' started by Fubeca, Dec 17, 2003.
  1. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I just pulled my t-case off and about a quart of ATF poured out. I just had both the t-case and tranny rebuilt. Which is my most likely candidate? Is their an easy way to tell -- the seal on the t-case doesn't look bad?
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    I would say the tranny seal is shot.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Did you drain the t-case first? Just removing the bolts on a 208 (and I think the 241) will let the fluid run out, as the holes are threaded all the way into the inner cavity of the t-case. If that's what happened, then it's normal. /forums/images/graemlins/cool.gif But if the t-case was drained and the fluid came out of the adapter itself, then most likely the rear seal on the tranny is leaking. /forums/images/graemlins/frown.gif
  4. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Yep, It was drained -- and plenty came out so I don't think it was leaking from the t-case side.
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Bummer! Sounds like it's time to have a chat with the rebuilder. /forums/images/graemlins/frown.gif
  6. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I pull my 208 fill plug everytime I do an oil change and let a quart or 2 drain out. Then top off the tranny as needed. Guess I have an automatic fluid change system /forums/images/graemlins/rotfl.gif
    I have been told by a trans shop its the rear trans seal. Should fix it someday.
    BTW, not to hi-jack the post, is this condition really a problem? what can happen? pressure build up and blow the trans case seal or ?? Havent found anyone say its a real problem yet.
    If you just had it rebuilt, you should talk to your trans builder about fixing it.
  7. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    I don't know what trans you have, but it is normal for ATF to come out of the tailshaft area in a TH350(and others). There is an ATF lubed bushing pressed into the trans body which supports the tailshaft. There is a small hole in the open area below the bushing for the fluid to drain back into the trans pan. If the fluid is only in the adapter, it may be ok.
    Jeff /forums/images/graemlins/usaflag.gif
  8. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Well, I just called the guy who rebuilt it and another tranny shop and they both said it was normal. It just didn't happen before the tranny and t-case were rebuilt -- maybe that was one of the problems. /forums/images/graemlins/crazy.gif
