Tranny fluid leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by globaljames, Aug 24, 2005.
  1. globaljames
    globaljames Registered Member
    Apr 2, 2004
    52
    AZ. Scottsdale
    Hi all,
    After a late night run through the Az Desert the other night I am leaking some tranny fluid. Seems like its comming from in front of my xfer case. On the way back my service eng light came on so I checked the fluids they looked ok besides the washer ( but it was dry before )
    Anyone have similar leaks ? Fixes or upgrades to stop this kind of thing. Thanks James
  2. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    check the bolts from teh adaptor to the x-fer case...when mine was reinstalled at the tranny shop, they didn't torque them down (at all is my guess) and they backed out after a day of wheeling...they ended up pullin it off and RTVin it real well.
  3. LAZYMON
    LAZYMON 1/2 ton status Premium Member
    Jul 26, 2000
    235
    Lake Tahoe
    I also have developed a leak at that location. Is there a gasket between the transfer case and transmission that could be bad?
  4. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    I think there's an oring.
  5. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    Yes, there is a paper gasket between the adapter and transfer case.
  6. blazinbm
    blazinbm Newbie
    Dec 19, 2003
    Central CA
    There's four bolts that attach the mount to the transmission, my blazer is on the injured list because the bottom bolts fell out because they were stripped out. I could not find the leak for about a month, by then it was too late, the back portion around the shaft broke where the top two bolts attach to the mount.
  7. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    There is an o-ring between the tailshaft of the trans and the transfer case adapter. That is where I got my ATF leak. It was a simple replacement. Drop the rear driveline. Remove 4 bolts on adapter and slipe the case back a few inches. Drop in the new o-ring and bolt it all back up. No RTV.
