tranny fluid question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bross82, May 8, 2002.
  1. Bross82
    Bross82 1/2 ton status
    Feb 11, 2002
    215
    Spencer, MA
    hey, i was wondering if most of the tranny fluid was drained if when i removed the cover last summer and replaced the filter.... i heard that there is still a lot left in the torque converter even if you do this... i'm just curious as far as how well this flushed out the old fluid.
    thanks,
    matt
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    There should be some left in there, is my understanding. Most shops "power flush" the tranny. They replace something like 3 gallons of fluid, I think. Anyone else?
  3. J.R.
    J.R. Guest
    by droping the pan you replaced about half the tranny fluid. as long as the fluid has good color and dosent smell burnt i would say its good to go. unless you have had the trans since it was new and you serviced it regular i wouldnt do the total fluid exchange.
  4. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    When I just pull the pan off and change the filter, it will take about 4 quarts to fill it back up. The entire system (depending on what pan, torque converter, etc. that you have) will usually hold about 12 quarts.
  5. Bross82
    Feb 11, 2002
    215
    Spencer, MA
    alright, thanks.
    matt
