Tranny fluid?, T-case leak?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JF 89K5, Oct 24, 2000.
  1. JF 89K5
    JF 89K5 Registered Member
    Mar 13, 2000
    68
    Shoshone, Idaho
    My 89 K5 with a 700R4 is leaking fluid from the rear of the T-case where the driveshaft goes in. I check the T-case fluid level and it's never low. Lately though my tranny fluid has been low. My ? is could my tranny fluid be low due to the leaking transfer case? I didn't think the tranny and T-case exchanged fluid, but I know that they both use transmission fluid. I just rebuilt the tranny(3000 miles ago) and there are no signs of leaks anywhere else.
    Thanks,
    JF
  2. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    Here we go again! [​IMG] This problem seems (to me) to happen a lot.
    From the info I have gotten, when the 'rear tranny seal'/'front transfer case seal' (they're the same seal) goes bad, tranny fluid leaks into the transfer case from the tranny. This can cause the transfer case to leak fluid out of the back shaft housing.
    You can check to see if your transfer case is overflowing by filling up your tranny, and then loosening the fill (top) plug on the transfer case. If fluid comes spilling/pouring/flying[​IMG] out, then the seal is bad and the tranny is overflowing the transfer case.
    That has been my take on the various discussions that happen around here about this problem. Everybody feel free to correct me. You can do a quick search on something like "transfer case rear seal leak" or some combination of those to find a lotta threads and messages about it. Hope this helped.
    <font color=blue>I don't get stuck, I'm just in the mud when I stop for lunch [​IMG]
    - NJFourWheelers</font color=blue>
  3. JF 89K5
    Mar 13, 2000
    68
    Shoshone, Idaho
    Thanks Panther,
    How hard is it to replace the rear seal on the tranny? As long as I keep the tranny fluid full, is it bad to drive it with a bad seal?
    JF
  4. SilverSolder
    SilverSolder Registered Member
    Oct 19, 2000
    16
    Sunnyvale, CA.
    My '82 just had the same problem. The repair amounted to replacing the seal between the tranny and the t-case. The mechanic told me that there is only one seal and it's located in the tcase.
    SilverSolder
  5. KILLERK5
    KILLERK5 1/2 ton status
    Oct 19, 2000
    108
    Aurora, Colorado
    I JUST REPLACED MY SEAL, AND IT STILL LEAKS! THE SEAL IS PRETTY EASY TO CHANGE
  6. JF 89K5
    Mar 13, 2000
    68
    Shoshone, Idaho
    I am assuming that I have to drop the t-case to replace the rear tranny seal? Do I need to take the t-case apart?
    JF
